1 Reply Latest reply on Nov 28, 2013 10:55 AM by GregT42
    Image "_files" folders not being copied to output
    GregT42
      This is an RH10 WebHelp project.
      I've moved most HTM files into a new subfolder under "Project Files" by dragging them within RoboHelp. The xxx_files folders containing the images were not transferred and instead all the HTM files were modified with ../ added to the src= entry. I then manually moved the xxx_files folders into that location and updated each HTM to point to the correct src location.
      The end result is partial success, the images show up fine in the RoboHelp editor but when the build is generated the xxx_files folders are not copied. In fact one does get copied and I have no idea what is different about that one
      Does anyone know of a simple resolution for this as I have about 48 topics that are not working?
      Thank you very much.
