1. Re: Video Dropping Frames and audio dropping out during playback
JSS1138 Nov 27, 2013 7:30 PM (in response to lukestirtz)The dropped audio is a known issue, and as you noticed, pausing and resuming playback brings it back.
Dropped frames is something else. That will be dependant on a few things, not just drive speed. The CPU and memory will also have an impact.
2. Re: Video Dropping Frames and audio dropping out during playback
lukestirtz Nov 29, 2013 2:33 PM (in response to JSS1138)Is the audio dropping still an unresolved issue? I know it's been doing this for months.
I'm running a 3.4GHz processor with i7, plus 16GB of ram. I think I'm maxed out on all fronts as far as this iMac goes. Do you know specifically where the problem could be generating from?
Sent from my iPhone
3. Re: Video Dropping Frames and audio dropping out during playback
JSS1138 Nov 29, 2013 5:24 PM (in response to lukestirtz)I don't believe the recent 7.1 update corrected the audio dropouts. I haven't noticed it happening, but I consider it a very minor annoyance at best and it's possible it's happened and I just didn't notice.
For the dropped frames, try moving it to an Internal drive.
4. Re: Video Dropping Frames and audio dropping out during playback
lukestirtz Dec 2, 2013 10:52 AM (in response to JSS1138)Maybe we're thinking of a different audio problem, but this makes it extremely difficult to watch through a sequence when the audio is constantly dropping out.
If using an internal drive is the only option, then that would eliminate using any external drive on the market because I don't know of anything that's much faster than a thunderbolt with Raid 0.
6. Re: Video Dropping Frames and audio dropping out during playback
Mark Mapes Dec 2, 2013 1:53 AM (in response to lukestirtz)This issue has been discussed at some length recently in this thread: http://forums.adobe.com/message/5863482#5863482
Worth a look as at least two or three workarounds have been presented.
7. Re: Video Dropping Frames and audio dropping out during playback
lukestirtz Dec 5, 2013 11:16 AM (in response to Mark Mapes)Thank you, I'll check it out.
