1. Re: Putting Adobe Premiere 11.0 on another PC.
John T Smith Nov 28, 2013 8:20 AM (in response to ole geezer)Premiere Elements has a different forum http://forums.adobe.com/community/premiere_elements
Write your downloaded file(s) to a DVD or USB hard drive... along with a text file containing your serial number
2. Re: Putting Adobe Premiere 11.0 on another PC.
JSS1138 Nov 29, 2013 10:06 AM (in response to ole geezer)[Moved to Elements forum.]
3. Re: Putting Adobe Premiere 11.0 on another PC.
whsprague Nov 29, 2013 10:20 AM (in response to ole geezer)Geezer,
Adobe allows two installations on the same serial number. So, you should be fine on the second computer.
The problem may come when you try to put the first one back together. Adobe's computers may see it as a third computer.
There are two solutions. Under the help menu is a "Deactivate" choice. It tells Adobe you are done using Premier Elements on that computer. You may have to "Deactive" the second one for a fresh install on the first.
The other solution is to send Adobe customer support an email explaining the loss of the first computer and they can reactivate for you. Nobody can do that here because it is a user forum.
Good luck...
Bill
4. Re: Re: Putting Adobe Premiere 11.0 on another PC.
ole geezer Nov 29, 2013 11:17 AM (in response to JSS1138)thanks, it's done now.
Bob H
