1 Reply Latest reply on Dec 16, 2007 11:02 PM by gavinnosler
    Dynamic Text Box Scrolling Problem
      I'm having an issue with a dynamic text box that's set to be selectable. The text box fits the content inside without cutting anything off, but when you select some text and drag down to select it all, it scrolls 1 line. The line is blank, and there's no reason it should be scrolling at all because the text frame doesn't cut anything off.
      To recreate the problem just create a dynamic text box and fill it with a paragraph of text. Make sure the text box fits the content perfectly. Set the text box to be scrollable.Test the movie and select some text at the top, then drag the selection all the way to the bottom. It should jump down a line and cut off the line at the very top.
      Any ideas here??? It's pretty annoying... :)
