6 Replies Latest reply on Nov 29, 2013 1:28 PM by benko214
    Justified margins become wavy when I export a large file to PDF. Any way to prevent this?
    benko214 Level 1
      When I export a large file with justified margins to PDF, the right margin becomes uneven. The attached images below show what it looks like in inDesign (left) and what it looks like as a PDF (right). This is a problem because I need to convert to PDF in order to print.
      The margins do do not become left-aligned. They are more even than that, but still not as even as justified lines should be.
      This is a very large file - 7 by 7 feet - consisting of more than a thousand lines of text. I do not have the same problem with smaller files.
      This occurs on multiple computers. I have tried everything on Adobe's "Troubleshoot printing, PDF export" page.
      Any suggestions would be greatly appreciated!
        • 1. Re: Justified margins become wavy when I export a large file to PDF. Any way to prevent this?
          @benko214 – What InDesign (exact version), what OS platform?
          Did you include the font in your PDF? And if yes, how?
          Can you show us the export settings with screen shots?
          If Acrobat Pro is available, can you show the Fonts tab in the Document Properties of the PDF?
          Uwe
          • 2. Re: Justified margins become wavy when I export a large file to PDF. Any way to prevent this?
            benko214 Level 1
            Thanks for your reply, @Laubender.
            I'm using CS6, Version 8.0.2 on a Mac running OS 10.6.8 (haven't switched to CC because my machine isn't supported).
            I've used the default (High Quality Print) export settings (I've pasted the summary below. It would take several screen shots to capture all the info, but I'll do that if that would be more useful). I've also used the bare bones ones Adobe's troubleshooting guide recommends and get the same result.
            I only have Adobe Reader and Preview, but the font certainly looks correct and justification works fine on documents with less text.
            - Ben
            Export settings:
            Description
                Use these settings to create Adobe PDF documents for quality printing on desktop printers and proofers.  Created PDF documents can be opened with Acrobat and Adobe Reader 5.0 and later.
            PDF Preset: [High Quality Print]
            Compatibility: Acrobat 5 (PDF 1.4)
            Standards Compliance: None
            General
                Pages: All
                Spreads: Off
                Generate Thumbnails: Off
                Optimize PDF: On
                Create Acrobat Layers: N/A
                Export Layers: Visible and Printable Layers
                Include Bookmarks: Off
                Include Hyperlinks: Off
                Export Nonprinting Objects: Off
                Export Visible Guides and Baseline Grids: Off
                Create Tagged PDF: On
                Interactive Elements: Do Not Include
            Compression
                Color Images
                    Bicubic Downsample at: 300 ppi
                    for images above: 450 ppi
                    Compression: Automatic
                    Tile Size: N/A
                    Quality: Maximum
                Grayscale Images
                    Tile Size: N/A
                    Quality: Maximum
                Monochrome Images
                    Bicubic Downsample at: 1200 ppi
                    for images above: 1800 ppi
                    Compression: CCITT Group 4
                Compress Text and Line Art: On
                Crop Image Data to Frames: On
            Marks and Bleeds
                Crop Marks: Off
                Bleed Marks: Off
                Registration Marks: Off
                Color Bars: Off
                Page Information: Off
                Page Mark Type: Default
                Weight: 0.25 pt
                Offset: 0.0833 in
                Use Document Bleed Settings: Off
                Bleed Top: 0 in
                Bleed Bottom: 0 in
                Bleed Inside: 0 in
                Bleed Outside: 0 in
                Include Slug Area: Off
            Output
                Color Conversion: No Color Conversion
                Destination: N/A
                Profile Inclusion Policy: Include Tagged Source Profiles
                Simulate Overprint: N/A
                Output Intent Profile Name: N/A
                Output Condition: N/A
                Output Condition Identifier: N/A
                Registry Name: N/A
            Advanced
                Subset Fonts Below: 100%
                Omit PDF: Off
                Omit EPS: Off
                Omit Bitmap Images: Off
                Transparency Flattener Preset: N/A
                Ignore Spread Overrides: N/A
            Security
                N/A
            • 3. Re: Justified margins become wavy when I export a large file to PDF. Any way to prevent this?
              Eugene Tyson Adobe Community Professional & MVP
              Hmm that's a strange one.
              The only thing I could suggest is exporting your document to IDML
              http://forums.adobe.com/thread/526991
              Then open that IDML file
              Don't scroll don't do anything once it opens, don't zoom, don't press any buttons!
              Then try the export.
              This doesn't solve your issue per se
              But how about just make the doucment 8.4 inches x 8.4 inches
              The printing companies can scale the document up by a factor of 10 to get the right result.
              As you said, it works fine on smaller documents.
              Or if you have it in PDF - try placing that in a 84 inch square document and export that.
              OR you could try placing your current InDesign file inside another Indesign file at the same size - and see if the export is still wonky.
              Or Place the 8.4 inch InDesign document in a 84 inch square indesign file and scale it up.
              If they don't make sense then let me know and I will elaborate.
              • 4. Re: Justified margins become wavy when I export a large file to PDF. Any way to prevent this?
                benko214 Level 1
                Thanks for all these ideas, Eugene.
                I tried the IDML and got the same result. Also got the same result when I made the document 8.4x8.4 inches. It must be the large number of lines on a single page that's tripping InDesign up rather than the size itself. Same when I pasted the current InDesign file into a new one and exported from there.
                I'm not sure I understand the other ideas. I don't have a working PDF I could put inside another InDesign document because all of my PDFs of this document have the same issue.
                -Ben
                • 5. Re: Justified margins become wavy when I export a large file to PDF. Any way to prevent this?
                  So which viewer is giving you the wavy lines? Preview or Reader?
                  • 6. Re: Justified margins become wavy when I export a large file to PDF. Any way to prevent this?
                    benko214 Level 1
                    Both. And we ended up printing it with a wavy margin by accident as well, so it's not just an issue with the viewer.
