6 Replies Latest reply on Dec 2, 2013 2:38 PM by asydd
    App not installing on simulator after Xcode update
    ozy08 Level 1
      I've just installed the latest Xcode updates and now when I test the App from Flash CC, it does not appear on simulator? The simulator launches OK however, my app icon does not appear. How can I fix this problem, it was working OK berfore I did the update?
        • 1. Re: App not installing on simulator after Xcode update
          asydd Level 1
          If you find an answer, please yell loudly !
          • 2. Re: App not installing on simulator after Xcode update
            meenat3
            Could you please let me know if you are able to find the installed app under following location: User/<username>/Library/Application Support/iPhone Simulator/7.0 folder.
            Please Quit the the Simulator and try deleting 7.0 folder. Then, repeat the process of installing tha app on iOS Simulator again. This time the app-icon should get visible.
            Let us know if this works for you.
            Regards,
            Meenakshi
            • 3. Re: App not installing on simulator after Xcode update
              ozy08 Level 1
              Hi
              I was unable to locate the folder
              There was no Library folder under my <username> however there was under the folder "Shared", but it did not have a "iPhone Simulator" folder.
              I did a "reset content and settings" which is a menu option in the ios simlator, however it did not correct the problem.
              The path to the ios simulator I am using is Applications/Xcode.app/Contents/Developer/Platforms/iPhoneSimulator.platform/Developer/SDK s/iPhoneSimulator7.0.sdk
              and this lauches OK with a version number of ios 7.0.3 displayed at the top.  However, my app icon still does not appear.
              Shoud  the Library/Application Support/iPhone Simulator/7.0 folder path get created automatically when I run the simulator?
              • 4. Re: App not installing on simulator after Xcode update
                meenat3 Level 2
                The path for iOS Simulator, you have provided is correct.
                The Library folder is hidden, so please make sure the folder is not hidden. You could also try Go-> Go to Folder and then type ~/Library.
                When the app is installed on iOS Simulator, it gets saved to the above said location:
                Hence, please try deleting folder 7.0 and then install the app on iOS Simulator.
                Regards,
                Meenakshi
                • 5. Re: App not installing on simulator after Xcode update
                  ozy08 Level 1
                  Thanks, thats great, my app is now appearing in the simulator again!
                  • 6. Re: App not installing on simulator after Xcode update
                    asydd Level 1
                    Excellent - thank you for the info.
                    For a new Mac user it took a bit to get the hidden folders to show, couldn't follow your promt but found to use in Terminal:
                    defaults write com.apple.finder AppleShowAllFiles TRUE
                    So now, yes the above worked and for the first time in months, iOS Simulator back on the road.
                    Next question: I can't publish to the iPad, is there a similar resolve for OS X 9.5 and iOS 7.
                    First run through on the app I just put to the newly invigorated Simulator gave: Syd: Unable to install the application. Ensure that the selected devices are connected.
                    The device is connected, switched on and selected.
