This content has been marked as final.
Show 1 reply
1. Re: Puppet Pins don't rotate ?
Trevor Dennis Nov 29, 2013 10:24 PM (in response to StrongBeaver)Are you saying that you have a number of objects on the same layer? Are they cut out, (is the rest of the layer transparent?) Does the mesh cover the entire layer, or just the object?
When you say Shapes, do you mean vectored objects that appear in the Paths panel, or are they rasterized (just pixels with no points?)
Is there any reason the shapes are not all on seperate layers? Puppet warp will work much better if they are.
