1 Reply Latest reply on Dec 17, 2007 10:11 AM by robva65
    Reordering quiz questions
    manekenl
      Hello,
      I wondered if I can safely change the order of questions by dragging and dropping slides. There doesn't seem to be a way of doing it in the Quiz Manager.
      Thanks in advance,
      Phil
        • 1. Re: Reordering quiz questions
          robva65
          manekenl,
          You should be able to reorder question slides at the PowerPoint level using the slide view, because you're right, there isn't an option to reorder question slides using the Quiz Manager.
          One thing to keep in mind, however, is that if you have more than one Quiz, you may still need to keep all the associated question slides together. In other words, you may run into programming/reporting errors if you overlap question slides from different quizzes.
          Rob
