Sirs,
I call LiveCycle on JBoss 5.1 server (livecycle ES3 turnkey installation) using EJB API without problem on one machine.
When in cluster, I would like loadbalance calls between two nodes. But I'm unable to do that. All calls are processes by same node. I use such a simple code:
jndi.properties:
java.naming.factory.initial= org.jnp.interfaces.NamingContextFactory
java.naming.provider.url=node1:1100,node2:1100
test.java:
Properties connectionProps = new Properties();
ServiceClientFactory myFactory = ServiceClientFactory.createInstance(connectionProps);
HashMap<String,String> hmInput = new HashMap<String, String>();
hmInput.put("a","10");
hmInput.put("b","20");
for(int i=0;i<5;i++) {
InvocationRequest ir = myFactory.createInvocationRequest("tst/NewProcess1", "invoke", hmInput, true);
InvocationResponse ires = myFactory.getServiceClient().invoke(ir);
System.out.println("Result: " + ires.getOutputParameter("c"));
According to JBoss documentation (http://docs.jboss.org/jbossclustering/cluster_guide/5.1/html/clustering-jndi.html), there should be round robin implementation and calls should be processed by both nodes.
Can you help me, please?
--- Jaroslav
