0 Replies Latest reply on Dec 2, 2013 1:31 PM by macampbell_09
    Swf stopping in After Effects
    macampbell_09 Level 1
      Hello, I have a problem with a swf in After Effects.
      The Swf was built on the main Timeline in Flash CS6 as a frame by frame animation and it is ten frames long. I know symbols cause problems so I didnt use them.
      In After Effects, it only plays up until frame 5 and then holds on that frame. I the sequence bar last a full ten frames however, the animation stops on frame five. So frames 1-4 are different but frame 5-10 are the same.
      What could be the problem?
      I even went into Preferences > Media & Disk Cache and under XMP Metadata I unchecked "XMP IDs to Files on Import", and that didin't change anything.
