1. Re: Mail merge data/list from excel to existing pdf document that has text fields for address created
Gilad D (try67) Dec 3, 2013 1:44 AM (in response to mford_eugene)Possible either with the Mail Merge button in the Acrobat PDF ribbon in some versions of Office and Acrobat, or you'll need to use a script.
2. Re: Mail merge data/list from excel to existing pdf document that has text fields for address created
mford_eugene Dec 3, 2013 10:02 AM (in response to Gilad D (try67))thx, but i can't find mail merge button in acrobat X pro anywhere..hmm. office products irrelevant because i am stuck with a complex pdf document that doesn't convert to word doc correctly so no option to mail merge to pdf from within word. must mail merge excel data list of addresses to the text fields i've setup in the pdf document. why so hard to have mail merge a standard option from within acrobat? this is insane why this full pro version of acrobat doesn't seem to have mail merge function. thx for any help, including if you have access to a mail merge script as you mentioned and then i'd need help using script..never used acrobat scripts. Mike
3. Re: Mail merge data/list from excel to existing pdf document that has text fields for address created
Gilad D (try67) Dec 3, 2013 10:04 AM (in response to mford_eugene)I sent you a PM about the script option.
4. Re: Mail merge data/list from excel to existing pdf document that has text fields for address created
mford_eugene Dec 3, 2013 10:24 AM (in response to Gilad D (try67))will your script work with my acrobat 7 standard version? my access to acrobat X pro is through citrix portal/company software which means i don't have access to C drive/programs,etc to copy/paste the script file to acrobat install folder. i do own acrobat 7 standard and it's installed locally on my machine, however, i don't see option to create text fields with acrobat 7 standard either..so i think i'm stuck with somehow making this work with my X pro work version..hmm
5. Re: Mail merge data/list from excel to existing pdf document that has text fields for address created
MasterMcRap Dec 30, 2013 7:54 PM (in response to Gilad D (try67))Gilad D
Would you be able to send me this script as well. I work for a Property Management with over 400 Tenants. We would like to utilize the Mail Merge with a pdf file for CRPs.
6. Re: Mail merge data/list from excel to existing pdf document that has text fields for address created
Gilad D (try67) Dec 31, 2013 1:37 AM (in response to MasterMcRap)PM sent as well...
7. Re: Mail merge data/list from excel to existing pdf document that has text fields for address created
GYT Jan 17, 2014 10:45 AM (in response to Gilad D (try67))Would you please forward the script to me also ? Thanks !!
8. Re: Mail merge data/list from excel to existing pdf document that has text fields for address created
Gilad D (try67) Jan 17, 2014 11:19 AM (in response to GYT)See PM.
9. Re: Mail merge data/list from excel to existing pdf document that has text fields for address created
Carters84 Jan 31, 2014 12:54 AM (in response to Gilad D (try67))Please PM to me as well, many thanks.
10. Re: Mail merge data/list from excel to existing pdf document that has text fields for address created
Gilad D (try67) Jan 31, 2014 1:27 AM (in response to Carters84)Check your inbox...
11. Re: Mail merge data/list from excel to existing pdf document that has text fields for address created
wwjacky Feb 3, 2014 7:07 PM (in response to mford_eugene)Please PM me as well, thanks
13. Re: Mail merge data/list from excel to existing pdf document that has text fields for address created
DKBerg Feb 5, 2014 11:59 AM (in response to Gilad D (try67))Can you please send me the scrip and information to use it as well. I have about 1200 employee records to merge into a secured PDF.
14. Re: Mail merge data/list from excel to existing pdf document that has text fields for address created
Gilad D (try67) Feb 5, 2014 12:04 PM (in response to DKBerg)Check you inbox (Your Stuff - Private Messages) as well.
15. Re: Mail merge data/list from excel to existing pdf document that has text fields for address created
sharksfan Feb 7, 2014 10:54 AM (in response to Gilad D (try67))Hi Gilad D.
I would appreciate a copy of the script as well.
Thank you!
Stephen
16. Re: Mail merge data/list from excel to existing pdf document that has text fields for address created
Gilad D (try67) Feb 7, 2014 11:54 AM (in response to sharksfan)Since I was asked to do it by multiple people already I will post the link here. I hope the forum moderators will not consider this against the rules... The script in question can be purchased from here: http://try67.blogspot.com/2011/09/acrobat-mail-merge-and-email.html
17. Re: Mail merge data/list from excel to existing pdf document that has text fields for address created
aspiegel17 Mar 14, 2014 2:47 PM (in response to mford_eugene)Could you send me the script as well? Need to mail merge excel and PDF file but have never used scripts before. Thanks!
18. Re: Mail merge data/list from excel to existing pdf document that has text fields for address created
RichardFay May 21, 2014 4:56 AM (in response to Gilad D (try67))I am a novice at using adobe acrobat but I am interested in using a mail/data merge function with a pre-existing form, I checked out the link, thanks, but I would be interested in also understanding the "script" you reference. Are you still in a position to forward the script if so thanks I would appreciate it.
Richard
19. Re: Mail merge data/list from excel to existing pdf document that has text fields for address created
rednacardo Aug 16, 2014 10:26 PM (in response to Gilad D (try67))Hi Gilad!
Thank you for your information. However I have two questions.
Does it work with OSX + Acrobat XI?
Where do I have to run the script? In Excell, system terminal, Acrobat? Sorry to ask such a questions but I am newbie in Acrobat and I am just looking for a way to create mail merges in complex designs.
Thanks!
20. Re: Mail merge data/list from excel to existing pdf document that has text fields for address created
rednacardo Aug 17, 2014 12:13 AM (in response to rednacardo)I checked by myself. Yes it does.
21. Re: Mail merge data/list from excel to existing pdf document that has text fields for address created
PattiAdobe Aug 19, 2014 9:11 PM (in response to Gilad D (try67))Please send me the script as well.
22. Re: Mail merge data/list from excel to existing pdf document that has text fields for address created
merrymary1995 Aug 21, 2014 2:17 PM (in response to mford_eugene)Can you please send me the script as well?
23. Re: Mail merge data/list from excel to existing pdf document that has text fields for address created
Gilad D (try67) Aug 21, 2014 2:36 PM (in response to merrymary1995)I'm not sending this script to anyone. You can get it from the link posted above.
