1 Reply Latest reply on Dec 3, 2013 3:24 PM by carl type3
    Errors ajp_process_callback::jk_ajp_common.c (1954): Writing to client aborted or client network
    EnzymeGTD
      Hello,
      we have the following configuration:
      S.O. : Red Hat Enterprise Linux Server release 6.5
      Apache : 2.2.15
      Coldfusion 10 Standard update 12
      SElinux disable
      Iptables disable
      Configuring / etc / httpd / conf / mod_jk.conf
      # Load mod_jk module
      Jk_module LoadModule " / opt/coldfusion10/config/wsconfig/1/mod_jk.so "
      # Where to find workers.properties
      JkWorkersFile " / opt/coldfusion10/config/wsconfig/1/workers.properties "
      JkMountFile " / opt/coldfusion10/config/wsconfig/1/uriworkermap.properties "
      # Where to put jk logs
      JkLogFile " / opt/coldfusion10/config/wsconfig/1/mod_jk.log "
      # Where to put jk shared memory
      JkShmFile " / opt/coldfusion10/config/wsconfig/1/jk_shm "
      # Set the jk log level [debug / error / info]
      JkLogLevel info
      # Select the timestamp log format
      JkLogStampFormat " [ % a% b % d% H:% M: % S % Y ]"
      AddHandler jakarta- servlet. Cfm . Cfml . Cfc . Cfr. Cfswf
      In the log / opt/coldfusion10/config/wsconfig/1/mod_jk.log observe the following errors:
      [ Tue Dec 03 10:29:53 2013] [ 3754:140076806252512 ] [info ] jk_ajp_common.c ajp_process_callback :: (1954 ) : Writing to client aborted or client network problems
      [ Tue Dec 03 10:29:53 2013] [ 3754:140076806252512 ] [info ] jk_ajp_common.c ajp_service :: ( 2629 ): ( cfusion ) sending request to tomcat failed ( unrecoverable ) , Because of client write error ( attempt = 1 )
      [ Tue Dec 03 10:29:53 2013] [ 3754:140076806252512 ] [info ] jk_handler :: mod_jk.c ( 2718 ) : Aborting connection for worker = cfusion
      Can anyone tell how to solve this problem because the connection between apache and coldfusion degrade coming to collapse the system.
        • 1. Re: Errors ajp_process_callback::jk_ajp_common.c (1954): Writing to client aborted or client network
          carl type3 Level 4
          Not my particular environment Linux Apache however the way I read the mod_jk log content is very similar or same as this other thread and  detail in isapi_redirect log on Windows IIS environment.
          Thread:
          http://forums.adobe.com/message/5878493#5878493
          MOD_JK log sample:
          ISAPI_redirect log sample:
          [info] ajp_process_callback::jk_ajp_common.c (1984):
          [info] ajp_service::jk_ajp_common.c (2684):
          (cfusion) sending request to tomcat failed (unrecoverable),
          because of client write error (attempt=1)
          [info] HttpExtensionProc::jk_isapi_plugin.c (2289):
          service() failed because client aborted connection
          Where I am seeing that sequence of log, CF10 IIS is not having any issue so it may not actually relate to the CF10 not responding. I would like to find a glossary of tomcat messages and the meaning however I have not got an
          interpretation to that log sequence. I will add the sites for me that have those logs have BYO wireless clients and it would be fair to say those users do not log off CF application however just close their browser or lid of laptop. Neither have I been able to reproduce the environment to cause that log detail so merely guess from me rather than statement of fact.
          HTH, Carl.
