8 Replies Latest reply on Dec 5, 2013 4:48 AM by wgst
    multible select
    wgst
      How can I slect all objects to the end of the timeline to move them?
        • 1. Re: multible select
          Click and drag over the clips you want to select then, once they're selected, drag them to a new location.
          You can view your entire timeline at once by pressing the \ key on your keyboard.
          • 2. Re: multible select
            wgst Level 1
            Hi Steve,
            the problem is that I mainly have pictures in my projects, and it is a normal task to insert a picture from another source (second camera, other photographer). So it is extremely uncomfortable to proceed in your way. I normally start with a project containing one day that means round about 100 to 200 pictures. And if I have to select them several times each single item I will get creasy.
            Michael
            • 3. Re: multible select
              the_wine_snob Level 9
              Michael,
              If you just drag your new Clip/Image to the same Video Track, with your existing assets, do those Clips/Images to the right of where you are dragging, not move to accommodate the new one? They should all move by the Duration of that new Clip/Image.
              Good luck, and let us know what happens, please.
              • 4. Re: multible select
                wgst Level 1
                Hi Hunt,
                the problem is that I mainly have pictures in my projects, and it is a normal task to insert a picture from another source (second camera, other photographer). I normally start with a project containing one day that means round about 100 to 200 pictures. And if I have to select them several times each single item I will get creasy.
                Regards
                Michael
                • 5. Re: multible select
                  If you just want to put a photo between existing clips on your timeline, why not just insert it? The other clips will move aside to accommodate you.
                  • 6. Re: multible select
                    Michael,
                    Perhaps I do not understand what you wish to accomplish and what you have on the Timeline, or perhaps I was not clear in my post.
                    Let's say that you have 200 Still Images on your Timeline, but want to insert a new one, between #20 and #21. You want #21 through #200 to move to the right, to accommodate the new Image. If you just drag that new Image to between #20 and #21, no modifier keys used, it should cause #21 through #200 to move to the right, by the Duration of that new Image. Is that not happening for you?
                    • 7. Re: multible select
                      wgst Level 1
                      Hi Hunt,
                      thank you. I don’t expect that the task is so easy!
                      Regards
                      Michael
                      • 8. Re: multible select
                        wgst Level 1
                        Hi Steve,
                        Regards
                        Michael
