0 Replies Latest reply on Dec 3, 2013 3:53 AM by flashygfx
    After using modify/contents some frames go out of stage dimension
      I have a question to all you animators out there.
      I work in after effects and sometimes do some simple illustrations/animations in flash - where I usually switch the bg colour to gray
      as not to see the stage rectangular as it's distracting to me. Then when I have my drawings and a few different frames done I go to
      modify/ choose bg colour to white and check contents to frame all the content inside the document - then I want to export it to swf
      so I can use it in after effects.
      At this point all seems fine, all the frames are in place, however I noticed that frequently when I reopen my flash documet after having done this some frames are outside
      the white stage box (usually later frames, the 1st is in place).
      How do you deal with this?
