7 Replies Latest reply on Dec 20, 2013 6:28 AM by A.T. Romano
    Can I import 264 files into Premiere Elements 11
    PhilipD123
      I get a generic error when I attempt to import some 264 files. These were created on a cctv system.
        • 1. Re: Can I import 264 files into Premiere Elements 11
          It depends on what format they're in and how you got them from your camcorder to your computer.
          What model of camcorder are these videos coming from and what resolution are they?
          Also, have you ensured you have the latest version of Quicktime, per the program's requirements?
          • 2. Re: Can I import 264 files into Premiere Elements 11
            A.T. Romano Level 7
            PhilipD123
            If I am correct we went through a recent rounds on this type of question recently. Those files are not the typical video files with H.264 video compression. I suspect that what you have are typically output from security cameras.
            These files are not supported by Premiere Elements and converting them to another format may be difficult.
            That recent thread on 264 files can be found
            http://forums.adobe.com/message/5880014#5880014
            There is no answer to the issue in that thread. The sample file never got through.
            I just found the following article that seems to confirm what I suspect your video properties are
            http://www.tomshardware.com/forum/241320-49-play-files#.
            See if any of the discussion in this link sheds some light on your situation.
            Thanks.
            ATR
            • 3. Re: Can I import 264 files into Premiere Elements 11
              As well as what has been posted, here is how you find out what is in the files
              Codec & Format information, with 2 links inside to read
              -read both links in reply #1 http://forums.adobe.com/thread/1270588
              Report back with the codec details of your file, use the programs below... A screen shot works well to SHOW people what you are doing
              http://forums.adobe.com/thread/592070?tstart=30 for screen shot instructions
              For PC http://mediainfo.sourceforge.net/en or http://www.headbands.com/gspot/
              For Mac http://mediainspector.massanti.com/
              And, in the future, the information you need to provide when you ask a question
              Premiere Elements FAQ http://forums.adobe.com/thread/1042180
              • 4. Re: Can I import 264 files into Premiere Elements 11
                VDOSurfer Level 3
                You can import .264 files into Premiere Elements 11 and 12.
                • 5. Re: Can I import 264 files into Premiere Elements 11
                  A.T. Romano Level 7
                  VDOSurfer
                  Could you give more information about your import of .264 into Premiere Elements 11 and 12?
                  Thanks.
                  ATR
                  • 6. Re: Can I import 264 files into Premiere Elements 11
                    VDOSurfer Level 3
                    As soon as I saw this post, I searched for the .264 extension in my hard drive. Found two files - could play both of them in Premiere Elements 11 and 12. Just imported them and played them on the expert room timeline.
                    Pathetic quality of the video though. I am not sure how these are there in my hard drive! Got to check with my friends for whom I have edited some projects if it belongs to them.
                    The complete Mediainfo output from one of the files.
                    Format                                   : MPEG-4
                    Format profile                           : Base Media / Version 2
                    Codec ID                                 : mp42
                    File size                                : 1.02 MiB
                    Duration                                 : 22s 0ms
                    Overall bit rate mode                    : Constant
                    Overall bit rate                         : 388 Kbps
                    Encoded date                             : UTC 2007-07-11 04:58:13
                    Tagged date                              : UTC 2007-07-11 04:58:14
                    Video
                    Format                                   : MPEG-4 Visual
                    Format profile                           : Advanced Simple@L3
                    Format settings, BVOP                    : Yes
                    Format settings, QPel                    : No
                    Format settings, GMC                     : No warppoints
                    Format settings, Matrix                  : Default (H.263)
                    Codec ID                                 : 20
                    Duration                                 : 22s 0ms
                    Source duration                          : 22s 11ms
                    Bit rate mode                            : Constant
                    Bit rate                                 : 256 Kbps
                    Width                                    : 352 pixels
                    Height                                   : 288 pixels
                    Display aspect ratio                     : 1.222
                    Frame rate mode                          : Constant
                    Frame rate                               : 30.303 fps
                    Standard                                 : PAL
                    Color space                              : YUV
                    Bit depth                                : 8 bits
                    Scan type                                : Progressive
                    Compression mode                         : Lossy
                    Bits/(Pixel*Frame)                       : 0.083
                    Stream size                              : 682 KiB (65%)
                    Source stream size                       : 682 KiB (65%)
                    Language                                 : English
                    Encoded date                             : UTC 2007-07-11 04:57:37
                    Transfer characteristics                 : BT.601
                    Matrix coefficients                      : BT.601
                    Audio
                    Format                                   : AAC
                    Format/Info                              : Advanced Audio Codec
                    Format profile                           : LC
                    Codec ID                                 : 40
                    Duration                                 : 22s 0ms
                    Source duration                          : 22s 13ms
                    Bit rate                                 : 128 Kbps
                    Channel(s)                               : 2 channels
                    Channel positions                        : Front: L R
                    Sampling rate                            : 44.1 KHz
                    Stream size                              : 344 KiB (33%)
                    Source stream size                       : 345 KiB (33%)
                    Language                                 : English
                    Encoded date                             : UTC 2007-07-11 04:57:35
                    • 7. Re: Can I import 264 files into Premiere Elements 11
                      A.T. Romano Level 7
                      VDOSurfer
                      As always, many thanks for the follow up.
                      My recollection is that, within the past few months, the Adobe Premiere Elements Forum has had at least 2 threads which related to this .h264.
                      I may pursue this when I get a chance to determine define the factors which make this format compatible with Premiere Elements whatever version. Your report of what you found works for you in this situation is extremely helpful. As I write, the answers are in the details. And, your details are most interesting and appreciated.
                      Best wishes,
                      ATR
