0 Replies Latest reply on Dec 3, 2013 1:13 PM by hpatel616
    InDesign CC - tranparency
    hpatel616
      I'm currently working on a file which uses many object and text frames. I've assigned object styles to various frames (image, text, etc). The problem i am having is with applying a transparency. On one of the frames, i want to have a 15% transparency. When doing so, it applies it to every frame on the page (including the image). I've started from scratch, redid object styles, but I can't figure it out.
      Seems like if i convert the image into RGB, the transparency works fine. However, i need the image to be Grayscale in which case, i run into this issue.
      Have never come across this in the past with IND.
