1 Reply Latest reply on Dec 19, 2007 6:15 AM by Peter Farland
    Flex Compiler and Java Compiler
    Ankit Thakur
      Greeting of the day,
      I Ankit Thakur wants to know that if we are using Java and Flex together then how can we compile both java and flex files together using flex compiler and java compiler. I am using Eclipse IDE.
      Please guide me.
        • 1. Re: Flex Compiler and Java Compiler
          Peter Farland Level 3
          Hi Ankit,
          I replied to your other question which is essentially the same.
          You first create Java projects in Eclipse and then you can add a Flex Project nature to them.
          Be sure to use the relevant perspective when editing files. That is, when editing Java files, make sure you're using the Java perspective. When editing MXML or AS files, make sure you're using the Flex Developer perspective.
