2 Replies Latest reply on Dec 15, 2013 11:16 PM by charanseeram
    Can we assign  html tags color/size/face to textFrame.contents of inDesign ?
    charanseeram Level 1
                                      var cellInstructionText:String = <TEXTFORMAT LEADING="2"><P ALIGN="LEFT"><FONT FACE="Arial" SIZE="12" COLOR="#FF0000" LETTERSPACING="0" KERNING="0">tetst instu</FONT></P></TEXTFORMAT>
        var layerText:TextFrame;
        layerText = myPage.textFrames.add();
        layerText.geometricBounds = [cell_y,cell_x,cell_y+cell_height,cell_x+cell_width]; // consider them as y1,x1,y2,x2
        //this below Reg expression gives only text content of above string
        var tagRegExp:RegExp = new RegExp("<([^>\\s]+)(\\s[^>]+)*>", "g");
        layerText.contents = cellInstructionText.replace(tagRegExp, "");     // Out put: testst instu
      Here , I have to apply it's 1)color, 2) size and 3)face of above string to the textFrame content of indesign document  , is this possible in any other way  apart from below Case _1 ?  coz , Case_1 way is getting complex when string holds multiple  colors/ fonts/face for single line of text and  am afraid what would be the case for multiple paragraph line of text ?.
      Is their any other indesign api classes are helpfull ?  in applying html tag contents of  colors/size/ to textframe contents of indesign ?
                                       Case_ 1:
        var content:String = cellInstructionText;
        var sizes:Array = new Array();
        sizes = content.match(/SIZE\s*=\s*["'](\d{1,})["']/);
        // array is null if no matches found:
        if ( sizes != null ) {
        size = sizes[1];
        layerText.texts.item(0).pointSize = size;
        var faces:Array = new Array();
        faces= content.match(/FACE\s*=\s*["'](.[^"']*)["']/);
        if ( faces != null ) {
        face = faces[1];
        layerText.texts.item(0).appliedFont = app.fonts.item("face");
        var colors:Array = new Array();
        colors = content.match(/COLOR\s*=\s*["'](.[^"']*)["']/);
        if ( colors != null ) {
        color = colors[1];
        var myColor:Object = myDocument.colors.item("color");
        try {
        layerText.texts.item(0).fillColor = myColor.name;
        catch (myError){
        //The color did not exist, so create it.
        /*layerText.texts.item(0).fillColor = myDocument.colors.add({name:"color", model:ColorModel.process,
        colorValue:[0,100,100,0]}); */
        • 1. Re: Can we assign  html tags color/size/face to textFrame.contents of inDesign ?
          • Reg Expression couldn't able to handle the number of proboblity's were the TextFormat string contains , and i was doing some xml parsing has below ,
                  Please let  me know if i can do better than this .
          var xmlConvertedText:XMLList = XMLList(""+cellInstructionText+"");
          for(var i1:int=0;i1<xmlConvertedText.children().length();i1++)
              var _rowOfXmlConvText:XML = xmlConvertedText.children()[i1];
              if(_rowOfXmlConvText != null)
                    for(var j1:int=0;j1<_rowOfXmlConvText.children().length();j1++)
                      var _dataOfRow:XML = _rowOfXmlConvText.children()[j1];
                      applyStyles(_dataOfRow,layerText);
          public function applyStyles(_fontData:XML,textLayer:TextFrame):void{
                          trace("NAME: "+_fontData.name());
                          for each (var att:XML in _fontData) {
                              trace("Attribute: "+att.name()+" = "+att);
                              trace(_fontData.text());
                              if(_fontData != null && _fontData.nodeKind() != 'text'){
                                  var face:String  = _fontData.@FACE;
                                  var size:String  = _fontData.@SIZE;
                                  var strColor:String = _fontData.@COLOR;
                                  var content:String = _fontData.text();
                                  //apply content
                                  if(content!=""){
                                      textLayer.parentStory.insertionPoints.item(-1).texts.item(0).contents = content+" ";
                                      //Clear the find/change text preferences.
                                      app.findTextPreferences = NothingEnum.nothing as FindTextPreference;
                                      app.changeTextPreferences = NothingEnum.nothing as ChangeTextPreference;
                                      //Search the document for the string "Text".
                                      app.findTextPreferences.findWhat = content;
                                      var mFound:Object = app.activeDocument.findText();
                                      var len:Object = mFound.length;
                                      if(size!=""){
                                          mFound[0].pointSize = size;//     ">0" in case of nothing found
                                      if(face!=""){
                                          mFound[0].appliedFont = app.fonts.item(face);
                                      if(strColor!=""){
                                          mFound[0].fillColor = myDocument.colors.add({space:ColorSpace.RGB,colorValue:[parseInt(strColor.substr(1,2),16) , parseInt(strColor.substr(3,2),16), parseInt(strColor.substr(5,2),16)]});
                          if (_fontData.children()==_fontData) {
                              trace("VALUE: "+_fontData.children());
                              trace("-----------------");
                          } else {
                              trace("This node has children:");
                              for each (var item:XML in _fontData.children()) {
                                  applyStyles(item,textLayer);
          • 2. Re: Can we assign  html tags color/size/face to textFrame.contents of inDesign ?
            Now i have to figure out how i can fix the problem of <B>bold content  </B> and <I>italic content  </I> in above method of apply styles , is their any refrence links avilable ? please let me know .
