1. Re: Blu-Ray Export Settings
Stan Jones Dec 4, 2013 10:53 AM (in response to jackdelamare)Export an ISO of the project and then burn that onto discs, or should I burn to discs straight from Encore?
Partly because Encore burning effectiveness was poor in the past, many of us have never tested it in CS6. So I much prefer build to image (or folder) and burn with something else (I use ImgBurn).
Secondly, should I build a BD-R or a BD-ROM (and would I need different discs?) I want these Blu-Rays to play in most Blu-Ray players if not all.
The selection of disk type when building to an image is regarding the type of disk you will use. Re the compatibilitgy issue, see this thread, starting with Neil's post at 16:
http://forums.adobe.com/message/5450695#5450695
how do I name the Blu-Ray disc so for example, when someone puts it in their PS3, it says the title of my film instead of "untitled"?
Not where I can check it, but I believe you just have to name the disk in disk properties. (Select the "disk" in the flowchart, or click in an open area of the project panel.)
