The help is not modular, as far as I know; MainHelp is just
what the developer has chosen to call the file once it gets to him.
When I compile it, it's called Solution-Centre-[version]-Help.chm.
The kicker is, the help window appears perfectly well on an
identical screen in the module where the message box appears, but
not in the module where there is no message box (there is some
duplication of functions between modules for workflow purposes).
For instance, if I go into our module called Document
Management, where a notification message box appears on startup,
and go to the feature called Manage Invoices, and hit F1, the help
appears just fine. If I go into the Rebate Management module, where
there is no equivalent notification on startup, and go to Manage
Invoices (the identical feature in a different module) hit F1, the
same help call is logged (not the sample one I put there -- the map
ID is 117 and the topic name is different) as in the other module,
but no help window appears.
