3 Replies Latest reply on Dec 5, 2013 9:06 AM by gallegosdavidm
    Changing page size
      I have InDesign CS6 and have a document with text and objects with page size A4. I need to change the page size to Letter and want the text and objects to adjust accordingly. How do I do this?
        • 1. Re: Changing page size
          Eugene Tyson Adobe Community Professional & MVP
          Edit>Layout Adjustment
          Then resize your document.
          • 2. Re: Changing page size
            Steve Werner Adobe Community Professional & MVP
            This only really works if you've consistently aligned objects on the page to guides.
            • 3. Re: Changing page size
              Just did a quick test in IDCC.
              Layout>Alternate Page Layout
              In the text box select the page size to adjust to and and use Scale in Liquid Page rule drop down, this will get everything scaled up or down to fit on your new page size but it ignores margins and guides. There are other settings to experiment with in the Create Alternate Layout dialog probably trial and error until you find what works for your application.
              This creates a second layout in your existing document.
              To adjust existing document try layout>liquid Layout scale then use the page tool Shift+p you can drag corners to preview for pennant change to take place use Alt+drag
