• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
CF Reporting using objects
Guest
Dec 05, 2013 Dec 05, 2013
I already have a very complex dynamic query the displays a list on the webpage. Now I need to pass this result set as object or csv or xml to CFR and produce a report.
how to do this?
Views
579
Translate
Translate
Report
Report
Community guidelines
community guidelines
Adobe Employee ,
Hi jolakammu,
You may try something like the below code:-
<cfquery name = "query_name" dataSource = "db_name">
     select * from table_name
</cfquery>
<cfspreadsheet
                                             action = "write"
                                             filename="AgentReport.xls"
                                             query="query_name"
                                             overwrite="true">
<cfform>
      <input type="button" value="Report Download" onClick="window.location.href='AgentReport.xls'">
</cfform>
Regards,
Anit Kumar
Votes
Translate
Translate
Report
Report
Guest
May be I was not clear on my question. Now how to pass this data to a coldfusion report and generate nice looking (header, footer, body, bolding , page number, grouping etc) report as pdf. Thanks.
I mean, how to make this csv as a datasource and create a report template (.cfr)
Votes
Translate
Translate
Report
Report
Participant ,
Dec 09, 2013 Dec 09, 2013
LATEST
Here this is a simple example of generating report using query object by "cfreport" tag and report template.
http://coldfusion-tip.blogspot.com/2013/11/using-coldfusion-report-template-to.html
If you want to use a CSV data in report template then I think you need to convert CSV into Query object then follow the process descriobed in the above URL.
For CSV to Query coversion, you may refrer following links or you can write your own functon:
http://cflib.org/udf/CSVToQuery
http://www.bennadel.com/blog/501-Parsing-CSV-Values-In-To-A-ColdFusion-Query.htm
For more knowledge about ColdFusion reporting please refer following links:
https://learn.adobe.com/wiki/display/coldfusionen/cfreport
http://help.adobe.com/en_US/ColdFusion/10.0/Developing/WSc3ff6d0ea77859461172e0811cbec22c24-6fc2.htm...
Votes
Translate
Translate
Report
Report
Resources
Documentation
