2 Replies Latest reply on Jan 3, 2008 1:44 PM by Baal Bebb
    Populating dynamic text field with form data from previous frame
    Baal Bebb
      I've got a dynamic text field (name) and I'd like to populate it with the values from two fields in a form from a previous frame. Does anyone know how to transport user-input values from one frame to another frame?
      Here's the code I'm using to capture the user-entered data:
      var submitListener:Object = new Object();
      submitListener.click = function(evt:Object) {
      var result_lv:LoadVars = new LoadVars();
      result_lv.onLoad = function(success:Boolean) {
      if (success) {
      result_ta.text = "Thank you for completing this training module.";
      } else {
      result_ta.text = "Error connecting to server.";
      var send_lv:LoadVars = new LoadVars();
      send_lv.fname = fname.text;
      send_lv.lname = lname.text;
      send_lv.email = email.text;
      send_lv.sendAndLoad(" http://distance.uaf.edu/ferpa/process.php", result_lv, "POST");
      gotoAndStop("certificate");
      submit_button.addEventListener("click", submitListener);
      Is there any way to capture the values from the fields 'fname' and 'lname' (which are instance names not variable names)? Note: I had to make them instance names in order for the code to be accessible to LoadVars() and hence to my php processing script.
      thanks,
      sage
