1. Re: How to change the color of a title halfway?
JSS1138 Dec 5, 2013 8:02 PM (in response to CptHatteras)I think you will need two titles for this.
2. Re: How to change the color of a title halfway?
shooternz Dec 5, 2013 8:03 PM (in response to CptHatteras)Two title clips with a transiition placed on them.
Cant get easier or simpler apart from a magic wand.
3. Re: How to change the color of a title halfway?
CptHatteras Dec 5, 2013 8:12 PM (in response to shooternz)thanks guys
I think if you could change it in the same clip without copying another title would be simpler and easier, thats just a personal preference, perhaps from having worked with other software that allows it, but the way you described it, its easy enough as well. Not sure if you can accomplish the same degree of progressive transformation from one color to another though. The transition helps sure, but not sure its the same than a gradual chromatic change
cheers
4. Re: How to change the color of a title halfway?
shooternz Dec 5, 2013 8:15 PM (in response to CptHatteras)Fair enough.
I think I would do that in AEFX with a key frame workflow then. Would need to experiment,
Interested...what does that?
5. Re: How to change the color of a title halfway?
shooternz Dec 5, 2013 8:18 PM (in response to shooternz)OK
JUst did a test on a white title.
Apply Premiere 'Change to Color Effect' and Key Frame it.
Works here
6. Re: How to change the color of a title halfway?
CptHatteras Dec 5, 2013 9:17 PM (in response to shooternz)I was going to say camtasia but Im not actually sure, the one that surely does it, its BluffTitler
Im not really sure how to keyframe the change color effect, Ive tried before I asked this question because it seemed the obvious answer but after applying the keyframes it didnt change color, so I deduced it wasnt meant for text
do youve got by any chance any tutorial or screenie to help me see the right way?
cheers
7. Re: How to change the color of a title halfway?
shooternz Dec 5, 2013 9:25 PM (in response to CptHatteras)No tutorial. I just applied Change to Color Effect and had a brief fiddle with it.
You apply start color and end color and keyframe the parameters of choice,
8. Re: How to change the color of a title halfway?
Steven L. Gotz Dec 5, 2013 9:41 PM (in response to CptHatteras)Simple. Just use the Fast Color Corrector on the title and animate any change you want. Start with a white title and go from there.
9. Re: How to change the color of a title halfway?
shooternz Dec 5, 2013 10:06 PM (in response to Steven L. Gotz)Did you try that Steven?
I will out of interest tomorrow.
10. Re: How to change the color of a title halfway?
Steven L. Gotz Dec 5, 2013 10:20 PM (in response to shooternz)Yes I did.
I was not at all sure it would work. I thought it should and it did. But you can be sure I always check this stuff unless I preface a message with something like "I am away from my editing PC".
Here is a little example. I could have used hold keyframes to jump from color to color instead.
