1 Reply Latest reply on Dec 9, 2013 3:32 PM by ophello
    Applescript: Packaging and exporting PDFs for multiple files -- need some tweaks
    ophello
      I found and tweaked a droplet script that isn't quite working right. I am hoping for some help with getting it to work the way I want. I tried and failed to learn to do this myself. Your help is greatly appreciated!
      Here's an example: I drag two files called "filename.indd" and "filename2.indd" onto the droplet. The script I have right now will output the packages and PDFs into the following folder structure:
      export folder
           filename folder
                filename.pdf
                filename folder
                     filename.indd
                     [Package contents]
           filename2 folder
                filename2.pdf
                filename2 folder
                     filename2.indd
                     [Package contents]
      Here's the folder structure I need (using a dialog box or script that intelligently knows that the directory to save in is the same as the files I dragged on to the droplet would be amazing):
      dialog box to choose new directory set to baseFolder
      or
      baseFolder <---- set to the current directory of the files I dragged onto the droplet
           filename folder
                filename.indd
                [Package contents]
                PDF folder             <--------new folder "PDF" created
                     filename.pdf
           filename2 folder
                filename2.indd
                [Package contents]
                     filename2.pdf
      Here's a script I found and modified:
      property baseFolder : (path to desktop as text) & "exports:"
      on open mgItems
                repeat with mgThisItem in mgItems
                          tell application id "com.adobe.InDesign"
                                    try
        open mgThisItem
                                              set mgDocName to name of active document
                                              set text item delimiters of AppleScript to ".indd"
                                              set mgShortName to text item 1 of mgDocName
                                              set targetFolderPath to my createFolder(mgShortName)
                                              set text item delimiters of AppleScript to ""
                                              set mgPackageFilePath to targetFolderPath & mgShortName as string
                                              set mgProofFilePath to mgPackageFilePath & ".pdf" as string
                                              set properties of PDF export preferences to properties of PDF export preset "[Smallest File Size]"
                                              tell the active document to export format PDF type to mgProofFilePath without showing options
                                              tell the active document to package to mgPackageFilePath with copying fonts, ignore preflight errors, copying profiles, updating graphics, including hidden layers, copying linked graphics and creating report
        close active document saving no
                                    on error e
        display dialog e
                                    end try
                          end tell
                end repeat
                display dialog "PDFs created and InDesign file packaged"
      end open
      on createFolder(nameString)
                set macFolderPath to baseFolder & nameString
                do shell script "mkdir -p " & quoted form of POSIX path of macFolderPath
                return macFolderPath & ":"
      end createFolder
      Thanks very much!
