1 Reply Latest reply on Dec 6, 2013 7:22 AM by Mylenium
    Holding last frame in composition
    Vandenberg_
      I have read that you can use Time Remapping to hold the last frame of a png sequence so that you can create a pause between transitions, without importing the last frame or anything.
      I have tried the technique described here >> http://forums.cgsociety.org/archive/index.php/t-90585.html but I think my workflow is in the way.
      My entire animation (+/- 600 frames) has been rendered in 3D and imported as one sequence in AFX. I composited my highlights and shadows in a composition and called it Master. Then I made smaller compositions and placed the Master comp inside them and cut it up to size. I placed the seperate sequences in a comp called Stage. So now I can just import one single sequence when I render again.
      So.. Now I am trying to let the last frame of the smaller sequences to hold for a few frames, before transitioning into the next. The Time Remapping just doesnt seem to work, because it is not holding anything when I move the last frame, it just shows the next part of the master animation.
      Is there a way around this or do I need to import every sequence as a unique set?
