8 Replies Latest reply on Dec 9, 2013 4:49 PM by Anit_Kumar
    Switch service account causes tomcat to load instead of iis
    PIM
      Hello,
      I have a site set up as default using Coldfusion 10. When I first started the website, I was using the Coldfusion Application Service as local and everything loaded fine.
      The client requires that I use a specific account in the service so it access certain folders that only this account has access privileges to. I did that and restarted the Coldfusion service.
      When I now go to the website, it gives me the Apache/Tomcat 500 error: "The server encountered an internal error () that prevented it from fulfilling this request."
      I do not understand why it is now trying to use Tomcat instead of IIS with just the service account being changed.
      I verified it has CFIDE and JAKARTA virtual directories there.
      Phil Mervis
        • 1. Re: Switch service account causes tomcat to load instead of iis
          Anit_Kumar Adobe Employee
          Hi PIM,
          All the CF services should be running under the same account and should have Read attributes, Read extended attributes and Read permissions on {coldfusion-home}/config/wsconfig and {coldfusion-home}/cfusion/wwwroot/CFIDE.
          Can you try again.
          Regards,
          Anit Kumar
          • 2. Re: Switch service account causes tomcat to load instead of iis
            PIM Level 1
            Hi Anit,
            Sorry for the delay in replying, I lost access to the server not much after you replied and didn't get it again until Monday morning.
            I changed the coldfusion application server service and the coldfusion .net service to the svc-wsb@api.dev logon. I couldn't change the jetty or odbc ones because the logon fails for those.
            I have given that account read access to the directories.
            It is still giving me the Apache Tomcat error. My biggest problem is that I've never been a server administrator and so I'm not terribly familiar with doing all of this. Most of my jobs have been in government where I had zero access to make these changes and this client expects me to do this.
            Phil
            • 3. Re: Switch service account causes tomcat to load instead of iis
              Hello Phil,
              I understand the scenario.
              PIM wrote:
              Hi Anit,
              Phil
              Can you let us know, if ColdFusion has ever worked. I mean does it work under Local System/Local Admin account. Are there any entries in the log file, related to the same?
              Regards,
              Anit Kumar
              • 4. Re: Switch service account causes tomcat to load instead of iis
                PIM Level 1
                Yes, I mentioned in the original post that I had the website loading fine using the local admin account. It would load fine with IIS loading the website and the pages showing up.
                Once I switch it to the other account for the Coldfusion Application service, it can't seem to connec the Tomcat to the IIS.
                As for the logs, if there are any I do not have access to Windows logs and there's nothing in the CF logs.
                Phil
                • 5. Re: Switch service account causes tomcat to load instead of iis
                  Hi Phil,
                  It seems like a permission issue, as a specific user is unable to access the application. Can you give the user account, permissions on the webroot and sub folders.
                  Regards,
                  Anit Kumar
                  • 6. Re: Switch service account causes tomcat to load instead of iis
                    PIM Level 1
                    Hi Anit,
                    I have given the user account permissions on the webroot and sub folders and still no problem. I'm at a loss on what to do with this.
                    It has read and list access to the main webroot plus all of its subfolders. I've also tried adding iusr to give that access as well.
                    • 7. Re: Switch service account causes tomcat to load instead of iis
                      PIM Level 1
                      This is what I get:
                      HTTP Status 500 -
                      type Exception report
                      message
                      description The server encountered an internal error () that prevented it from fulfilling this request.
                      exception
                      javax.servlet.ServletException: java.lang.NullPointerException coldfusion.bootstrap.ClassloaderHelper.initServletClass(ClassloaderHelper.java:129) coldfusion.bootstrap.BootstrapServlet.init(BootstrapServlet.java:59) org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:472) org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:98) org.apache.catalina.valves.AccessLogValve.invoke(AccessLogValve.java:928) org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:414) org.apache.coyote.ajp.AjpProcessor.process(AjpProcessor.java:203) org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:539) org.apache.tomcat.util.net.JIoEndpoint$SocketProcessor.run(JIoEndpoint.java:298) java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1145) java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:615) java.lang.Thread.run(Thread.java:722)
                      root cause
                      java.lang.NullPointerException coldfusion.CfmServlet.init(CfmServlet.java:82) coldfusion.bootstrap.ClassloaderHelper.initServletClass(ClassloaderHelper.java:121) coldfusion.bootstrap.BootstrapServlet.init(BootstrapServlet.java:59) org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:472) org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:98) org.apache.catalina.valves.AccessLogValve.invoke(AccessLogValve.java:928) org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:414) org.apache.coyote.ajp.AjpProcessor.process(AjpProcessor.java:203) org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:539) org.apache.tomcat.util.net.JIoEndpoint$SocketProcessor.run(JIoEndpoint.java:298) java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1145) java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:615) java.lang.Thread.run(Thread.java:722)
                      note The full stack trace of the root cause is available in the Apache Tomcat/7.0.23 logs.
                      • 8. Re: Switch service account causes tomcat to load instead of iis
                        Hi Phil,
                        Please add the user account to {coldfusion-home} and give Read attributes, Read extended attributes and Read permissions.
                        A list of permissions is defined for webserver at section 2.2.3.1 Web Root Content Security Permissions of http://www.adobe.com/content/dam/Adobe/en/products/coldfusion/pdfs/cf10/cf10-lockdown-guid e.pdf and the ColdFusion level permissions are mentioned at 4.1.2 Setup Permissions on ColdFusion installation directory
                        Regards,
                        Anit Kumar
