1 Reply Latest reply on Dec 9, 2013 11:19 AM by Sergey Anosov
    javascript print pdf + multi-page pdf for duplex printing
    bd@masha
      It’s not pretty, but it works.
      I’ve searched a lot for a script like this but had to do it myself.
      I use postage software to print postcards (2000+ a pop) for promotional mailers. I print to a PDF file (just started using NovaPDF after using Acrobat Pro (v7) for several years. Why? Because I lost over $100 in printed postage a long time ago when my computer/printer failed (and it’s a real pain getting them to give a refund).
      This script will take a ‘Message side’ PDF (page 1), and a (multi-page) PDF for page 2 (eg: my PDF file of printed addresses with postage), and print, in duplex (if your printer will), all your postcards. It’s fairly self explanatory, but I’ll add: it allows you to set printer-specific parameters on 1st page printed, then automatically uses same for rest.
      (I use it for other jobs, too, not just postcards)
      Hope someone finds it useful. Modify away...
      // "duplex-003.js"
          2 pages only
          page 1 (0) =  Picture(s) PDF
          page 2 (1) = Mailer PDF (multipage)
          we cycle thru page 2 pdf pages
      var myPages = myDoc.pages;
      // p0 = base page
      var p1 = myPages[1];
      var p2 ;
      var Grfx1 = p1.allGraphics[0];
      var GrfxProp1 = p1.allGraphics[0].properties;
      var indexpdf = p1.allGraphics[0].pdfAttributes.pageNumber;
      // set print box parameters for first print
      var printpagerange = "1,2";
                myDoc.printPreferences.pageRange = printpagerange;
                myDoc.print(true,undefined);
      // pdf page number starts at 1, not 0
      printpagerange = "1,3";
      var filepath = GrfxProp1.itemLink.filePath;
      while (1) {
          indexpdf++;
          app.pdfPlacePreferences.pageNumber = indexpdf;
          p2 = myPages.add();
          p2.place(filepath);
          if(indexpdf != p2.allGraphics[0].pdfAttributes.pageNumber) {
              p2.remove();
              break;
                myDoc.print(false,undefined);
          p2.remove();
      <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<< OR you can create a file to print later (faster but larger) >>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>
      // "duplex-003.js" -- create file
          2 pages only
        // p0 = base page
      var p0 = myPages[0];
      var p2 ;
      while (1) {
          indexpdf++;
          p2 = p0.duplicate(LocationOptions.atEnd,undefined);
          p2 = myPages.add();
          p2.place(filepath);
              p2.remove();
              break;
        • 1. Re: javascript print pdf + multi-page pdf for duplex printing
          Sergey Anosov
          Hi!
          Maybe this script will be helpful:
          https://sites.google.com/site/dtpscripting/indesign-scripts/imposemultipage-jsx
          In fact it does not give a direct solution of your task, but it can help. For example you can create a Master-spread containing a "non-personalized" page and a page with a text frame to place "personalized" PDF-pages in. An obvious problem is the numbering inside the text frames. But it is solvable too.
          You can create a text file in a spreadsheet application such as MS Excel, containing a column of numbers for "personalized" PDF-pages using increment functions for cells. Then save as/export that as a text file and place in the InDesign document using "auto-flow" with Shift key. The main thing is: the Paragraph style in the text frame on Master-spread must contain in "Keep options" the option "Start in next frame".  After that use this script to break the thread into separate text frames:
          https://sites.google.com/site/dtpscripting/indesign-scripts/breakstory
          or SplitStory.
          So you will have a "template" containing spreads with "non-personalized" pages and pages with text frames containing numbers for "personalized" PDF-pages.
          Finally run the first script ImposeMultiPage.jsx using created paragraph style for numbers.
