2 Replies Latest reply on Dec 8, 2013 3:11 AM by Peter Spier
    Indesign loads all my install files
    ellenaeddy
      When I start my indesign, it loads every start installation for every program on it and then displays a javascript error  2 and 24. Those will not go away and the program is unworkable.
      I am working on a windows 8 system. How do I fix this?
      I'm way out of my depth.
      I did recently load some javascript files suggested at Lynda.com. Could that be part of this?
      Ellen Anne Eddy
        • 1. Re: Indesign loads all my install files
          @Ellen – you did not say what version of InDesign you are using on what OS platform. That might be of help.
          Also screenshots  of the error messages would help:
          You mentioned installed scripts. As long as they are not recide in a "startup scripts" folder, they should not affect launching InDesign. So look it up, if  you installed those scripts in a "startup scripts" folder and simply put them out.
          Leave all other scripts in place!
          Then launch InDesign again. A system restart before could help …
          Uwe
          • 2. Re: Indesign loads all my install files
            Another useful test would be to create a new user on the computer, log in with that user, and try starting ID. Do the problems persist?
