Has anyone else noticed that if you use User Defined
Varibles, that the designer will remove the line break tag if the
line break tag is followed by the variable?
If I do the following (which I do heavily in my help file0:
Create a User Deifned Variable,
Create a new topic,
place text in the topic,
place a line break,
insert your user defined variable,
save the topic.
Now if you right click on the topic and view it, it will
display properly. If you open the topic again, you will find that
the line breaks have now been removed, if you don't save the topic,
it's ok, but if you save, of course you loose the line breaks.
Is this a program issue, or is this a user issue? I can't
really tell. I would expect that my line breaks shouldn't be
removed like this.
By the way, I am using RoboHelp 7.00.145.
Thanks.
