4 Replies Latest reply on Dec 10, 2013 3:38 AM by Beliakov
    why bridgetalk doesn't work in cycle?
    Beliakov Level 1
      i save three layers (from forst to third) to EPS and than open it in AI and resave as older EPS version (and some cleaning procedures).
      ////////////main cycle through layers
      for (ml=0; ml<mlayersName.length; ml++) {
      mLayers(mlayersName[ml]);
      function mLayers(mName)
      for(L = 0; L < mDoc.layers.length; L++){  /////////cycle for no visibility for all other layers
        if(mDoc.layers.item(L).name == mName){mDoc.layers.item(L).visible = true;}
        else{mDoc.layers.item(L).visible = false;}
          toEPS(mName);
          /// open in AI
          mFnameEPSIllu = mFname.split(".")[0]+"_" + mName + ".eps";
          var myFileIllu = File(mPath + mFnameEPSIllu);
                 var myArgumentsAsArray = [myFileIllu];
                                mscript = myIlluScript;
                          mscript += '\myIlluScript(' + myArgumentsAsArray.toSource()+ ');';
                          btMessaging( 'illustrator', mscript );
      }  //function mLayers(mName) END
      //////////////////saving in EPS from InDesign
      function toEPS(mName) {
      mFnameEPS = mFname.split(".")[0]+"_" + mName + ".eps";
      var myFile = File(mPath + mFnameEPS);
      if (mName.match("face") !=null){
          app.epsExportPreferences.pageRange = '3';
          }else if (mName.match("back") !=null){
              app.epsExportPreferences.pageRange = '1';
              }else{
                  app.epsExportPreferences.pageRange = '2';
      mDoc.exportFile(ExportFormat.epsType, myFile, false);
      function btMessaging( targetApp, mscript ) {
                var bt = new BridgeTalk();
                bt.target = targetApp;
                bt.body = mscript;
                bt.send();
      BridgeTalk.bringToFront( 'illustrator' );
      ////script string for AI ///resaving in EPS from AI
      function myIlluScript(aArray){
      app.open(aArray[0]);
      app.executeMenuCommand('selectall');
      app.executeMenuCommand('Fit Artboard to selected Art');
      var saveOptions = new EPSSaveOptions();
      saveOptions.compatibility = Compatibility.ILLUSTRATOR8;
      var saveName = new File (aArray[0]);
      $.writeln('file in AIscript: ' + aArray[0]); ////// !!!!!!!!!! this line appears only one time instead of tree!!!!!!!!!!!!!
          var docRef = activeDocument;
      docRef.saveAs(saveName, saveOptions);
      docRef.close();
         docRef = null;
      But AI script appears to work only once - very first iteration.
      Why does this happens?
        • 1. Re: why bridgetalk doesn't work in cycle?
          pixxxel schubser Level 5
          Too many variables are not defined. The snippet is not executable standalone.
          A guess: There is a "backslash-bug" between Bridge Talk and Illustrator. Maybe that's the cause.
          Or because of you do: app.open(aArray[0]); instead of loop through the aArray.
          Without seeing what the script does it is only a „look into the crystal ball“.
          Sorry.
          • 2. Re: why bridgetalk doesn't work in cycle?
            @pixxxel schubser – This "backslash-bug" is not only between BridgeTalk and Illustrator.
            It's a bug (?) with BridgeTalk. Independent of the app you talk to…
            @Demitry – Instead of using // to comment out your code, use always /*…*/ for comments when working with BridgeTalk.
            Uwe
            • 3. Re: why bridgetalk doesn't work in cycle?
              Hallo Uwe,
              ich hatte es zwar befürchtet, wollte aber trotzdem vorsichtig optimistisch bleiben.
              • 4. Re: why bridgetalk doesn't work in cycle?
                Beliakov Level 1
                interesting, that analog (this simplyfied) script do work properly.
                #target indesign
                var mDoc = app.activeDocument;
                fullDocName = mDoc.fullName;
                mPath = "/Users/somebody/Documents/tmp/";
                mFname = mDoc.name.toString();
                mlayersName = ['Layer 1', 'Layer 2', 'Layer 3'];
                for (is = mDoc.stories.length-1; is>=0; is--){
                    $.writeln(is);
                    try {mDoc.stories[is].createOutlines();}
                    catch (myError){};
                ////////////////////////////////// - main cycle - ////////////////////////////////////////////
                //выгонка EPS'ов по слоям
                function mLayers(mName) /* highlight the target layer */
                toEPS(mName);
                /* prepare modification name for EPS */
                                    mscript += '\myIlluScript(' + myFileIllu.toSource()+ ');';
                          bt.body = mscript;
                          bt.send();
                function myIlluScript(mEPS){
                app.open(mEPS);
                /* just for test of workin this subscript*/
                alert("Done!");
                after testing previous version, in AI i see only first opened file. That means, that strings of AI-script fulfils only once (in version of topicstarter).
