1 Reply Latest reply on Dec 9, 2013 5:37 PM by Carl Sun
    extension manager
    Ezequiel_Santos
      Olá amigos, meu extension manager não esta reconhecendo o dreamweaver, o que faço?
        • 1. Re: extension manager
          Carl Sun Level 4
          Which version of Extension Manager and Dreamweaver have you installed? Have you moved or renamed the Dreamweaver folder? Do you have Windows or Mac? Are you in a corporate network? Have you updated EM and DW to the latest version?
          Please note that Extension Manager only installs and manages extensions for the corresponding version of products. e.g., Extension Manager CC will not recognize Dreamweaver CS6, for which you should use Extension Manager CS6.
          Please run Adobe ExtendScript Toolkit (CS6, CC or whatever version you have installed), input the following command
          BridgeTalk.__diagnostics__;
          then click "Debug"->"Run" menu item, the diagnostics output will be shown in the Javascript Console window at the top right corner. You can copy all the output to a text editor because this window is too small. Please check whether Dreamweaver is listed under "Targets" section and the path is correct.
