0 Replies Latest reply on Dec 9, 2013 10:38 AM by Zoze
    Full Window Scale
    Zoze Level 2
      HI,
      I use the below code to scale my composition but in full (maximized) window doesn't fit the content correctly. A vertical scroll bar at the right of the windows appear's.
      Is it possible to fix it?
      var stageHeight = sym.$('Stage').height(); // Set a variable for the height of the stage
      sym.$("#Stage").css({ // Set the transform origin so we always scale to the top left corner of the stage
      "transform-origin":"0 0",
      "-ms-transform-origin":"0 0",
      "-webkit-transform-origin":"0 0",
      "-moz-transform-origin":"0 0",
      "-o-transform-origin":"0 0"
      function scaleStage() {
          var stage = sym.$('Stage'); // Set a reusable variable to reference the stage
          var parent = sym.$('Stage').parent(); // Set a reusable variable to reference the parent container of the stage
          var parentWidth = stage.parent().width(); // Get the parent of the stage width
          var stageWidth = stage.width(); // Get the stage width
          var desiredWidth = Math.round(parentWidth * 1); // Set the new width of the stage as it scales
          var rescale = (desiredWidth / stageWidth); // Set a variable to calculate the new width of the stage as it scales
      // Rescale the stage!
                 stage.css('transform', 'scale(' + rescale + ')');
          stage.css(  '-o-transform', 'scale(' + rescale + ')');
                 stage.css('-ms-transform', 'scale(' + rescale + ')');
          stage.css('-webkit-transform', 'scale(' + rescale + ')');
                 stage.css('-moz-transform', 'scale(' + rescale + ')');
          stage.css('-o-transform', 'scale(' + rescale + ')');
          parent.height(stageHeight * rescale); // Reset the height of the parent container so the objects below it will reflow as the height adjusts
      // Make it happen when the browser resizes
      $(window).on('resize', function(){
                 scaleStage();
      // Make it happen when the page first loads
      $(document).ready(function(){
          scaleStage();
