1 Reply Latest reply on Jan 10, 2014 12:32 PM by Josh_Corey
    Please help
    SuggaMomma
      FormsCentral could not import the PDF because field Group4 contains duplicate display values.
        • 1. Re: Please help
          Josh_Corey Adobe Employee
          Hi;
          If you have access to Adobe Acrobat you can edit the form and go through the fields in the right hand panel while in Form Editing mode, none of the fields can have the same name (display value).  Group 4 is likely a group of Radio buttons and each simply needs to be named uniquely, note that this does not change what a user sees in the PDF.
          Once you have gone through and updated any duplicate names you should be able to import the PDF.
          UPDATE: Here is an FAQ on how to fix this issue: http://forums.adobe.com/docs/DOC-4191
          Josh
