1 2 Previous Next 52 Replies Latest reply: Feb 26, 2014 12:30 AM by Apod42 RSS
    Find and replace text in multiple Photoshop files?
    Apod42 Community Member
      Hi there,
      Let us say I have six Photoshop files: 1.psd, 2.psd, ..., 6.psd. All of these files contain the word “LoremIpsum” in random text layers, within each document. Is there a way I can search for “LoremIpsum” in all documents and replace it with “Dolor Sit Amet”, all in one go? This is just an example, I need to replace various words, not just one.
      I have tried "batch find and replace" software (including powerful tools like Power Grep) but they do not work with psd files… Is there a javascript of external plugin for this kind of task?
      Thanks!
        • 1. Re: Find and replace text in multiple Photoshop files?
          c.pfaffenbichler Community Member
          Are the individual Type Layers uniform or do they combine text elements of any variation (size, font, spacing, …)?
          • 2. Re: Find and replace text in multiple Photoshop files?
            This should work on all open documents if the Type Layers’ content is uniform.
            // replace text elements in type layers;
            // 2013, use it at your own risk;
            #target photoshop
            if (app.documents.length > 0) {
                      for (var n = 0; n < app.documents.length; n++) {
                                app.activeDocument = app.documents[n];
                                app.activeDocument.suspendHistory("replace text", "main()")
            // the opertation;
            function main () {
                      var myDocument = app.activeDocument;
                      var theLayers = collectTextLayers(myDocument, []);
                      if (theLayers.length > 0) {
                                var theArray1 = ["LoremIpsum"];
                                var theArray2 = ["Dolor Sit Amet"];
                                for (var a = 0; a < theLayers.length; a++) {
                                          for (var b = 0; b < theArray1.length; b++) {
                                                    var theString = theLayers[a].textItem.contents;
                                                    while (theString.indexOf(theArray1[b]) != -1) {
                                                              theString = theString.replace(theArray1[b], theArray2[b])
                                                    theLayers[a].textItem.contents = theString;
            ////// function collect all layers //////
            function collectTextLayers (theParent, allLayers) {
                      if (!allLayers) {var allLayers = new Array};
                      else {};
                      for (var m = theParent.layers.length - 1; m >= 0;m--) {
                                var theLayer = theParent.layers[m];
            // apply the function to layersets;
                                if (theLayer.typename == "ArtLayer") {
                                          if (theLayer.kind == LayerKind.TEXT) {allLayers.push(theLayer)};
                                else {
                                          allLayers = (collectTextLayers(theLayer, allLayers))
            // this line includes the layer groups;
            //                              allLayers.push(theLayer);
                      return allLayers
            • 3. Re: Find and replace text in multiple Photoshop files?
              Thank you for the script! Will try to run it ASAP. The Type Layers are not uniform, font size, color, etc varies... Will the script work in this case?
              • 4. Re: Find and replace text in multiple Photoshop files?
                No, it won’t or rather is will destroy those variations.
                • 5. Re: Find and replace text in multiple Photoshop files?
                  Will let you know what happens... Thank you!!
                  • 6. Re: Find and replace text in multiple Photoshop files?
                    You were right, of course! Your script works perfectly, but it ruins the formatting of documents. Nonetheless, thank you! Maybe I will get to a solution from here.
                    • 7. Re: Find and replace text in multiple Photoshop files?
                      Document Object Model Scripting can not take care of that formatting fur parts of a Type Layer’s contents.
                      Action Manager code can, but it is not that easy.
                      Do you know how many factors do vary?
                      • 8. Re: Find and replace text in multiple Photoshop files?
                        There are 5 font variations within the documents. If it helps, I can list the font type, size, color, etc for each variation.
                        • 9. Re: Find and replace text in multiple Photoshop files?
                          What are the other two variable properties (apart from font, size and color)?
                          • 10. Re: Find and replace text in multiple Photoshop files?
                            When it comes to the characters I have these variations:
                            Font Family
                            Font Style (Regular, Italic, Bold, etc)
                            Font Size
                            Font Color
                            * Font tracking (?) - when font is justified, Photoshop assigns a value for this (I belive it is the spacing between characters).
                            These variations are for the characters. There are also a lot of variations when it comes to paragraphs.
                            I do start to believe that this is too much of a handful.
                            • 11. Re: Find and replace text in multiple Photoshop files?
                              Michael L Hale Community Member
                              It will be a handful. And how it's done will depend on which version of Photoshop you are using. It will require using Action Manager and adjusting not only the text string but either the text ranges( CS5 of lower ) or the text and paragraph ranges( CS6 or higher ).
                              The text descriptor is massive and even as experienced as I am with scripting I would do this manually.
                              • 12. Re: Find and replace text in multiple Photoshop files?
                                c.pfaffenbichler
                                I think your script might still be the solution. I will just make some changes to the text layers in my photoshop files (break them into multiple text layers) and everything should work fine.
                                Please, how would the script look if beside replacing "LoremIpsum" with "Dolor Sit Amet" I would also like to replace in the same go the words "Sun" with "Moon" and "Cold" with "Hot" ?
                                Thank you!
                                • 13. Re: Find and replace text in multiple Photoshop files?
                                  var theArray1 = ["LoremIpsum", "Sun", "Cold"];
                                                      var theArray2 = ["Dolor Sit Amet", "Moon", "Hot"];
                                  • 14. Re: Find and replace text in multiple Photoshop files?
                                    Thank you! Wish you all the best!
                                    • 15. Re: Find and replace text in multiple Photoshop files?
                                      Me again... If I used the script above (or a variant of it) to batch search/replace in just ONE Photoshop document, not multiple documents, would it still ruin font formatting?
                                      Is there any other script for batch search/replace inside one document, using Photoshop's built in tool?
                                      And is there a way to get the words in
                                      from an external .txt file, encoded in UTF-8? JavaScript just can't handle diacritics....
                                      Thank you!
                                      • 16. Re: Find and replace text in multiple Photoshop files?
                                        Seems »Find and Replace Text« is actually Scrip-able.
                                        #target photoshop
                                        // the opertation;
                                        function main () {
                                                  var theArray1 = ["TEST", "test"];
                                                  var theArray2 = ["HAHAHA", "LALALA"];
                                                            replaceText (theArray1[b], theArray2[b])
                                        ////// reoplace text //////
                                        function replaceText (replaceThis, replaceWith) {
                                        var idreplace = stringIDToTypeID( "replace" );
                                            var desc22 = new ActionDescriptor();
                                            var idnull = charIDToTypeID( "null" );
                                                var ref3 = new ActionReference();
                                                var idPrpr = charIDToTypeID( "Prpr" );
                                                ref3.putProperty( idPrpr, idreplace );
                                                var idTxLr = charIDToTypeID( "TxLr" );
                                                var idOrdn = charIDToTypeID( "Ordn" );
                                                var idAl = charIDToTypeID( "Al  " );
                                                ref3.putEnumerated( idTxLr, idOrdn, idAl );
                                            desc22.putReference( idnull, ref3 );
                                            var idUsng = charIDToTypeID( "Usng" );
                                                var desc23 = new ActionDescriptor();
                                                var idfind = stringIDToTypeID( "find" );
                                                desc23.putString( idfind, replaceThis );
                                                desc23.putString( idreplace, replaceWith );
                                                var idcheckAll = stringIDToTypeID( "checkAll" );
                                                desc23.putBoolean( idcheckAll, true );
                                                var idFwd = charIDToTypeID( "Fwd " );
                                                desc23.putBoolean( idFwd, true );
                                                var idcaseSensitive = stringIDToTypeID( "caseSensitive" );
                                                desc23.putBoolean( idcaseSensitive, false );
                                                var idwholeWord = stringIDToTypeID( "wholeWord" );
                                                desc23.putBoolean( idwholeWord, false );
                                                var idignoreAccents = stringIDToTypeID( "ignoreAccents" );
                                                desc23.putBoolean( idignoreAccents, true );
                                            var idfindReplace = stringIDToTypeID( "findReplace" );
                                            desc22.putObject( idUsng, idfindReplace, desc23 );
                                        executeAction( idreplace, desc22, DialogModes.NO );
                                        • 17. Re: Find and replace text in multiple Photoshop files?
                                          To answer some questions more directly:
                                          The handling of all open documents has nothing to do with the difficulties of Scripting Type Layers.
                                          Above Script uses the feature and it seems to not destroy varying formatting, if you want to run it on only the active document delete the lines
                                          and the corresponding closing bracket.
                                          • 18. Re: Find and replace text in multiple Photoshop files?
                                            I think that this conversation (and of course your know-how), has produced an amazing result. I belive that many people can make use of this script, I see that already Google indexed this page I have tested it extensively, and it works flawless, it's fast, and if I encode the .jsx file containing the script in UTF-8 it handles special characters (diacritics in my case) just fne.
                                            There is still one unanswered question (of minimal importance):
                                            Is there a way to get the words in
                                            from an external .txt file? So there is no need to modify the script for each operation, just modify the external file.
                                            Thank you again for all your time!
                                            • 19. Re: Find and replace text in multiple Photoshop files?
                                              You’re welcome, advice given here is free.
                                              If you want to donate something nonetheless you could do so over at
                                              http://ps-scripts.com/bb/
                                              Many of the same people used to contribute there as here and I for one have benefitted considerably from their generous advice on Scripting issues.
                                              A Script can read (or create) txt files, but I do not have a lot of experience with this.
                                              This might work (amend the line »var theTexts = readPref ("….txt", false);« according to your txt-file’s path):
                                              #target photoshop
                                              // the opertation;
                                              function main () {
                                                        var theArray1 = theTexts.slice(0, Math.round(theTexts.length/2));
                                                        var theArray2 = theTexts.slice(Math.round(theTexts.length/2), theTexts.length);
                                                        alert (theArray1.join("\n")+"\n\n\n"+theArray2.join("\n"))
                                              ////// read prefs file //////
                                              function readPref (thePath, binary) {
                                                if (File(thePath).exists == true) {
                                                  var file = File(thePath);
                                                  file.open("r");
                                                  if (binary == true) {file.encoding= 'BINARY'};
                                                  var theText = file.read();
                                                  file.close();
                                                  return String(theText).split(",")
                                              In this case the comma is used to split the text into Strings in Arrays, if your search/replace texts include commas you could use something else, I guess.
                                              • 20. Re: Find and replace text in multiple Photoshop files?
                                                Thank you! I will test with this script today, will also make a donation to the forum you indicated!
                                                • 21. Re: Find and replace text in multiple Photoshop files?
                                                  This is the body of the external file:
                                                  Sun,Moon
                                                  It replaces Sun with Moon. I just don't get how should I format the external text file to add more words to replace. Add for example Cold,Hot and Day,Night...
                                                  • 23. Re: Find and replace text in multiple Photoshop files?
                                                    I get it now, with a blank line (space) makes logical order... Will never think as a programmer
                                                    • 24. Re: Find and replace text in multiple Photoshop files?
                                                      Actually my approach may be a bit clumsy (not a programmer, either), listing the pairs might be more elegant; the for-clause
                                                      would have to be changed a bit then, though.
                                                      • 25. Re: Find and replace text in multiple Photoshop files?
                                                        More questions, only if you find the time...
                                                        By default, Photoshop's search tool searches only visible text layers. If a layer is hidden, no search is performed on that layer. Your script above acts in the same way. Is there a way to make the script bypass Photoshop's default, and also search (and replace) in hidden layers?
                                                        For anyone reading this in the future; there is a way to search hidden layers. Go to Window > Layer Comps. Select your hidden text layers, make them visible, and create a new layer comp (think of it as a document within a document). Do a layer comp for your main document also. When you search, select the comp with all the text layers visible. Then you can switch with just a click to your main version of the document. Sounds complicated, it's straightforward. Just remember about "Layer Comps".
                                                        Question two. The alert in your last script pops up like this:
                                                        You are about to search and replace: (doesn't actually say this, this line is my great addition to your script )
                                                        Sun
                                                        Day
                                                        Hot
                                                        Moon
                                                        Night
                                                        Cold
                                                        Is there a way to make the alert like this?
                                                        Sun
                                                        Moon
                                                        Day
                                                        Night
                                                        Hot
                                                        Cold
                                                        I guess this is this snippet of code here:
                                                        All the best!
                                                        • 26. Re: Find and replace text in multiple Photoshop files?
                                                          I would have made the text file a two line file. The first line would be for the search terms and the second for the replacement terms.
                                                          'Sun','Day','Hot'
                                                          'Moon','Night','Cold'
                                                          Then I would replace these lines
                                                          with these
                                                          var theTexts = readPref ("...filePath or file object");
                                                          var theArray1 = theTexts[0];
                                                          var theArray2 = theTexts.[1];
                                                          and replaced the readPerf function with this
                                                          function readPref (thePath) {
        file.open("r");
        var textArray = [];
        textArray.push(file.readln().split(","));// make array of search terms
        textArray.push(file.readln().split(","));// make array of replace terms
        file.close();
        return textArray;
                                                          Ideally it would have checks to make sure there are two lines and the number of terms match.
                                                          • 27. Re: Find and replace text in multiple Photoshop files?
                                                            Thank you! For me (Photoshop CS3), the updated script gives an error:
                                                            Error 1243: Illegal argument - Argument 2
                                                            -Required value is missing
                                                            Line: 41
                                                            -> desc23.putString(idreplace, replaceWith);
                                                            • 28. Re: Find and replace text in multiple Photoshop files?
                                                              My bad, it works.... Results are identical with previous version.
                                                              • 29. Re: Find and replace text in multiple Photoshop files?
        Yes, I expected the results would be the same. I just thought that having a two line text file with one line for the search terms and the second for the replacement terms was better than a one line text file. I think the two line text file is better because you don't have to count the terms to determine which is a search term and which is a replacement term.
        • 30. Re: Find and replace text in multiple Photoshop files?
        You are right, Mike, your approach offers advantages indeed.
        Setting up the file should be much more convenient thus.
        • 31. Re: Find and replace text in multiple Photoshop files?
        Thank you both very much, it has been a pleasure! I already started using the original script by c.pfaffenbichler, with additions by Michael L Hale
        Hope this thread will be of help to other people, in the future.
        Over and out
        • 32. Re: Find and replace text in multiple Photoshop files?
        Me again
        The script does a great job at replacing a word with another word. But how should I approach replacing a word with a few paragraphs of text? It works, but when it encounters a space betwen paragraphs (a blank line, like the one below) it stops.
        I have tried using \n (as I use in Javascript alerts) but it does not work... Is there another way?
        Thank you!!
        • 33. Re: Find and replace text in multiple Photoshop files?
        Could you post the Script and the txt-file you work with now?
        • 34. Re: Find and replace text in multiple Photoshop files?
        SCRIPT:
        #target photoshop
        function main () {
        var theTexts = readPref ("D:/Directory/text-file.txt");
        var theArray2 = theTexts[1];
        desc23.putBoolean( idFwd, false );
        desc23.putBoolean( idcaseSensitive, true );
        desc23.putBoolean( idignoreAccents, false );
        file.open("r");
        var textArray = [];
        textArray.push(file.readln().split("|"));
        file.close();
        return textArray;
        TEXT FILE:
        Sun|Night|Cold
        Moon|Day|Hot
        • 35. Re: Find and replace text in multiple Photoshop files?
        jdubbb
        First off, this would be super useful if I can get it working, so thanks so much in advance.
        Just tried running the above script posted by Apod42... But it returned this error. Any ideas?
        I'm running Photoshop CC.
        - The object “in contents of all text layer” is not currently available.
        Line: 48
        ->  executeAction( idreplace, desc22, DialogModes.NO );
        Many thanks!
        • 36. Re: Find and replace text in multiple Photoshop files?
        One could always foresake the readln in readPref and use some other letter/s to split the string in the txt-file into two. One would have to restructure the txt-file accordingly.
        • 37. Re: Find and replace text in multiple Photoshop files?
        Hello,
        Your last replay was for me or jdubbb? Show I work on this part:
        Get rid of the readln?
        As before, thank you!
        • 38. Re: Find and replace text in multiple Photoshop files?
        I’m off for the weekend, so unless someone else provides a solution in the meantime I’ll try to get back to you in a couple of days.
        • 39. Re: Find and replace text in multiple Photoshop files?
        jdubbb Community Member
        Just got it working!
        I made sure that I had just one of the target text layers selected in the layers panel.
        Thank you so much. Saved me SO much time.
        1 2 Previous Next
