1 Reply Latest reply on Dec 10, 2013 4:29 AM by Doc Maik
    pasted objects subject to default stroke and fill.
    phil_onebestway
      I am trying to copy information (objects and type) from an already completed project to a side project where everything needs to be identical to its original.  When I am copying my grouped selection from my CC document and pasting it into the new one the objects become subject to what appears to be a default stroke and fill rather than retaining the original attributes from the existing file.
      Could you please advise me on how to amend this issue.
      Thank you
      Phil
        • 1. Re: pasted objects subject to default stroke and fill.
          Doc Maik Level 4
          This is most probably because you might have altered the default object style (name like "Default object style") and not created a new one. Once you copy the objects to the other document, where it also has a default object style with that name, that object style is not overwritten (exactly because the name is equal) and the properties of that other style are applied.
          Solution: never use default objects styles. This is sometimes wanted to have paragraph or object styles with same names in different document, which only differ, for example, in the language setting.
