1 Reply Latest reply on Dec 10, 2013 2:17 PM by pixxxel schubser
    [AS][CS5] Reverse selected text
    JohnDevlon
      I'm trying to write a script to reverse selected text in Illustrator. Unfortunatly, An error is trown. Does anyone know why?
      The script ...
      tell application "Adobe Illustrator"
          set docRef to the current document
          set selectedItems to selection of docRef
          set myResult to my myReverse(the text of selectedItems)
          -- Error below
          set the text of selectedItems to myResult
      end tell
      on myReverse(myList)
           set myResult to {}
          set numOfItems to the (count of myList)
          set currentNum to numOfItems
          repeat with i from 1 to numOfItems
              set the end of myResult to item currentNum of myList
              set currentNum to currentNum - 1
          end repeat
          return myResult
      end myReverse
      display dialog "done"
        • 1. Re: [AS][CS5] Reverse selected text
          pixxxel schubser MVP & Adobe Community Professional
          Sorry, I have no experience with AppleScript.
          With Javascript I would do the following:
          // TextReverse.jsx
          // preconditions: an open document with a text frame with text inside (no selection required)
          // regards pixxxelschubser
          var reverseText = app.activeDocument.textFrames[0].contents.split("").reverse().join("");
          app.activeDocument.textFrames[0].contents = reverseText;
          Maybe this helps a little bit.
