1 Reply Latest reply on Dec 10, 2013 4:24 PM by jbowden
    Bugs Still?
    little blue surf0214
      In a large Html file using Edge Animate only to build it. When I switch one Action call from using "Labels" as the target to using 00:00.000 ALL actions become void. Tested it by switching the single Action back to "Label and file works *** usual?
        • 1. Re: Bugs Still?
          jbowden Adobe Employee
          Hi there,
          Yes, entering an invalid input (00:00.000) for a play or stop method can break a lot of Javascript since it's all bundled together and injected into the runtime and called when needed.
          Assuming you're are using a play() method, then you can either pass it a string (a label name in quotes, e.g., play("myLabel"), as you did - or a number in milliseconds, e.g., play(0) , which will start at time zero, or 1000 for 1 second, 2000 for 2 seconds etc.
          hth,
          Joe
