2 Replies Latest reply on Dec 12, 2013 12:39 AM by Rodrigo Olmos
    Which port uses aerender?
    Rodrigo Olmos
      Hi there,
      I have following problem. Since I installed the avast (antivirus/firewall) update 2014.9.0.2008, my BG Renderer script, respectively the aerender, won´t start to render anymore. I tried it with After Effects CC and CS6 with the newest and older versions of BG Renderer script.
      Lloyd Alvarez told me (after I send him two screenshots), that avast blocks the port aerender uses. The error is coming from aerender not BG Renderer. As long as I stop the firewall, all works fine.
      Here my question:
      Does anybody know which port aerender uses?
      Thanks in advance,
        • 1. Re: Which port uses aerender?
          Todd_Kopriva Level 8
          Avast causes lots of problems with applications that communicate over TCP, including the Adobe video applications. It has also been known to cause severe performance problems with Premiere Pro.
          I recommend using a different security application.
          • 2. Re: Which port uses aerender?
            Rodrigo Olmos Level 1
            Hi Todd,
            thanks for your response.
            Yes, the new avast version causes lots of problems. On an other machine, the 3ds max backburner won´t render with avast anymore, too.
            Anyway, the easiest way for me would be to 'unblock' the portnumber for aerender. Does a portnumber defined for aerender exist?
            If not, I will follow your advice.
