4 Replies Latest reply on Dec 11, 2013 10:59 PM by ingacha
    LDAP two fields merge
    ingacha
      I have connection with Adobe Livecycle and my company LDAP.
      I write a sql query, where get two values from LDAP- name(employees) and title(they position in company).
      This result i put in two dropdown list and need this field to merge. Now this field value is separately. What can I do to bring these value?
      Thanks!
        • 1. Re: LDAP two fields merge
          TundraSteve Employee Moderator
          I'm not certain what you're asking but I think you want to merge the selection of two dropdowns into a text field.  If that's what you want then on the exit event of the dropdown you could have something like
          TextField1.rawValue
          = DropDownList1.getDisplayItem(DropDownList1.selectedIndex) + ' ' +
          DropDownList2.getDisplayItem(DropDownList2.selectedIndex)
          • 2. Re: LDAP two fields merge
            ingacha Level 1
            I use other choise merge this dropdown list: this.rawValue=name.rawValue + " " + title.rawValue and get result one field.
            But I need other solution.
            I made a connection to Active Directory and got two attributes - employees and positions. Then I insert these two fields with attribute in LiveCycle and get the results from the Active Directory.When I choose DropdownList1 another employee in Dropdownlist2 (his position) does not change.
            For example,
            DropdownList1 - inga, janis, maris, liene, salvis ;
            DropdownList2 - maneger, director, analyst, programmer, seller.
            That meen - inga ir maneger, janis is director, maris is analyst...
            This data is from Active directory. Then I get a choise janis, in dropdownList2 dosn't appear his position. (left the first value - maneger)
            And what i need...a need make this dropdownList populated/merge from LDAP.
            I'm sorry about my English, it's not my native language.
            • 3. Re: LDAP two fields merge
              So if a user selects something in one dropdown you want to select the corresponding value in the other dropdown.
              DropDownList2.formattedValue
              DropDownList2.getDisplayItem(DropDownList1.selectedIndex)
              • 4. Re: LDAP two fields merge
                ingacha Level 1
                Yes, but this solution don't work.
                I choose from dropdownlis1 value, but in dropdownlist2 disappear/lost values.
