16 Replies Latest reply on Feb 12, 2014 1:26 PM by A.T. Romano
    pilote d'affichage
    Gilles35
      Bonjour,
      je viens d'installer Adobe Premiere Element 12 et quand je veux l'ouvrir, il me dit "nous avons détecté un pilote d'affichage incompatible. Pour de meilleures performances de lecture rapide veuillez mettre à jour votre pilote d'affichage." Que dois je faire. (j'utilise windows 8)
      Si quelqu'un peut m'aider ce serait avec plaisir...
        • 1. Re: pilote d'affichage
          A.T. Romano Level 7
          Gilles35
          The first thing to do is to assure that your computer has the latest version of the video card driver according to the web site of the manufacturer of the video card. After you go to the web site and determine that you have the latest version of the video card driver, then you delete the BadDrivers.txt file. The location of that file for Premiere Elements 12 running on Windows 8 64 bit is
          Local Disc C
          Program Data
          Adobe
          Premiere Elements Folder
          in the Premiere Elements Folder the BadDrivers.txt will be seen there as a file. There may be folders in the Premiere Elements Folder but you do not want them. You want the BadDrivers.txt file that exists in the Premiere Elements Folder as a file.
          Please make sure that you are working with the Folder Option Show Hidden Files, Folders, and Drives active so that you see the complete path to this BadDrivers.txt file. After you delete this current BadDrivers.txt file and open Premiere Elements, the program will generate a new BadDrivers.txt file.
          Please review and then let us know the outcome.
          Thank you.
          ATR
          • 2. Re: pilote d'affichage
            What is your exact brand/model graphics adapter (ATI or nVidia or ???)
            What is your exact graphics adapter driver version?
            Have you gone to the vendor web site to check for a newer driver?
            -If Windows, do NOT rely on Windows Update to have current driver information
            -you need to go direct to the vendor web site and check updates for yourself
            ATI Driver Autodetect http://support.amd.com/en-us/download/auto-detect-tool
            nVidia Driver Downloads http://www.nvidia.com/Download/index.aspx?lang=en-us
            • 3. Re: pilote d'affichage
              Gilles35 Level 1
              apparamment mes pilotes sont à jours (AMD Radoon HD 7670 M (8.982.6.0) et Intel (R) HD Graphics 4000 (8.982.6.0) et j'ai supprimé le fichier Baddrivers.txt mais ça me dit toujours la même chose
              • 5. Re: pilote d'affichage
                Gilles35 Level 1
                Ok merci,
                apparament ça marche, j'ai pu résoudre dans Catalyst Control Center en affectant le processeur haure performance à:
                - adobe premiere element 12 .exe
                et
                - gpusniffer.exe
                Merci beaucoup et bonne soirée
                • 6. Re: pilote d'affichage
                  Julien Valentin
                  J'ai exactement le même problème.
                  Voici la question que je viens de poster sur le forum,
                  As-tu eu une solution?
                  Bonjour,
                  - J’ai acheté, sur Amazon, Adobe Photoshop et Première Elements 12
                  - J’ai pu installer les deux DVD. Photoshop démarre normalement;
                  - Mais impossible de démarrer un nouveau projet avec Première (montage de vidéos): deux fenêtres successives s’affichent et indiquent que le pilote d’affichage serait incompatible et que je devrais le mettre à jour;
                  - J’ai posé la question sur un forum de Microsoft Community (titre: “Pilote d’affichage”);
                  En résumé, j’ai été orienté sur les cartes graphiques: “AMD Radeon HD 6470M” et “Intel(R) HD Graphics Family”
                  mais Windows me dit que les deux pilotes sont à jour; donc pas de solution sur ce forum.
                  - J’ai posé la même question sur un forum Sony ‘'(titre “Cartes graphiques et Adobe”) puisque mon ordi est un Sony VPCJ21S1E.  Mais jusqu’à présent, pas de solution efficace. Obliger les logiciels Adobe à fonctionner avec AMD n’a rien donné.
                  J’ajoute que j’ai sur mon ordi Elements 9 (les logiciels étaient installés à l’origine mais je ne les avais pas activés).
                  Or, en activant Eléments 9 pour une version démo (30 jours), les deux logiciels ont démarré correctement, y compris un “nouveau projet “ dans Première...
                  J’en suis amené à penser que Elément 12, trop récent, a un bug de programmation...
                  C’est quand même très frustrant d’avoir acheté Element 12 pour rien... alors que Element 9 fonctionne... mais seulement pour 30 jours!
                  Merci d’apporter une solution!
                  Il y a des chances que je ne sois pas tout seul à avoir ce problème...
                  Julien Valentin
                  • 7. Re: pilote d'affichage
                    Also asked in http://forums.adobe.com/thread/1394834?tstart=0
                    In this message, re-read reply #4 and see if it fixes your problem
                    • 8. Re: pilote d'affichage
                      Julien Valentin Level 1
                      Merci pour votre réponse et aussi pour celle de Bill Hunt
                      J'ai effectivement ouvert une nouvelle discussion "pilote d'affichage et element 12" avant de trouver celle-ci où j'ai remis le même message car j'ai exactement le même problème que Gilles35
                      Je suis sur ce problème depuis deux mois...
                      J'ai suivi la procédure de Gilles35 (voir #5). J'ai pu affecter à element 12 le pilote haute performance... mais cela n'a pas marché alors que j'ai les mêmes pilotes que Gilles35 (voir mes pilotes dans mon message précédent #6)
                      Vos autres solutions (#4) me semblent compliquées (le Bios???)
                      Il me faut une solution simple et non risquée parce que mon ordi marche très bien.
                      Comme element 9 fonctionne sur cet ordi (version démo)... je pense sérieusement acheter cette version ce qui serait un peu nul...
                      Merci pour votre aide,
                      Julien Valentin
                      • 9. Re: pilote d'affichage
                        Après avoir été sur d’autres forums et essayé diverses suggestions, mon problème avec Adobe Premiere Element 12 n’est pas résolu.
                        Finalement, je vais travailler avec VideoPad de NCH en attendant un éventuel correctif de Adobe... ou de changer d’ordi!
                        Merci pour le temps passé à tenter de trouver une solution.
                        Julien Valentin
                        • 10. Re: pilote d'affichage
                          A.T. Romano Level 7
                          Julien Valentin
                          Please excuse this late entry into your Premiere Element 12 "display issue". I would have to study all your posts, but based on what I see in this thread, I would ask
                          1. Did you pursue the deletion of the BadDrivers.txt file for Premiere Elements 12?
                          Local Disk C
                          Program Data
                          Adobe
                          Premiere Elements
                          and in the Premiere Elements Folder is the BadDrivers.txt file that you delete. Be advised, the BadDrivers.txt file is a file in the Premiere Elements Folder in that path cited. That Premiere Elements Folder has folders besides the BadDrivers.txt file. You only want the BadDrivers.txt file and not anything in those folders in the Premiere Elements Folder.
                          If you have not seen it before, post 10 in the following thread gives the rationale behind deleting the BadDrivers.txt file in certain display card driver issues.
                          http://forums.adobe.com/message/3177024
                          If I read your report correctly, I find it very interesting that you need Premiere Elements 9 installed on the same computer with Premiere Elements 12 in order to get Premiere Elements 12 to work for you. If I have understood that correctly, does Premiere Elements 12 continue to work if you uninstall Premiere Elements 9 from that computer....no leftover cleaning, just a regular uninstall via Control Panel/Installed Programs area.
                          Does your Premiere Elements 12 "work" if you install and run if from a new User Account with Administrastive Privileges on the same computer?
                          ATR
                          • 11. Re: pilote d'affichage
                            Hi Romano,
                            I'll try to write in English...
                            Thanks for your reply and advice...
                            I'll try to delete the famous "Bad drivers.txt file"... I'll do that for the fun as, now, I work with VideoPad ... In fact, I bought PE12 for nothing...
                            I think you did not read my report correctly.
                            PE12 was installed correctly... But it was impossible to start a new project (because of the wrong message about the cards).
                            But I had on this computer PE9: it was a "version d'évaluation"  (In French) never activated (it remains now 4 days...).
                            It was possible to open a new projet with this PE9, not with PE12....  PE12 didn't work when PE9 was installed.
                            Best,
                            Julien Valentin
                            • 12. Re: pilote d'affichage
                              Unfortunatly I didn't find the BadDriver.txt file...
                              However I followed your path and I found PE folder etc.
                              Some times ago, I tried the solution with "Administrative Privileges"...
                              Best,
                              Julien Valentin
                              • 13. Re: pilote d'affichage
                                the_wine_snob Level 9
                                Julien,
                                Do you have "Show Hidden and System Files" checked in the OS's Control Panel>Folder Options? If not, you will not see the BadDrivers.TXT file, but if you check "Show Hidden... " it should be right where ATR directed you.
                                • 14. Re: pilote d'affichage
                                  A.T. Romano Level 7
                                  Julien Valentin
                                  I do not recall seeing what computer operating system your Premiere Elements is running on.
                                  If it is Windows 7 64 bit, the easiest way to Folder Options is by clicking on Search and entering Field Options in the Search field above the Start Button. Then click on Folder Options that appears at that top left column of the screen. Next Folder Options/View/ and then scroll for the option of the Show Hidden Files, Folders, and Drives and make sure that it is selected.
                                  If you have Windows 8 or 8.1, go to the Metro interface, type File Explorer and follow that route to the View/Options/Change folder and search options/Folder Options/View/
                                  Please let us know the outcome when you find and delete the BadDrivers.txt file in the location that I cited back in post 10
                                  Local Disk C
                                  Program Data
                                  Adobe
                                  Premiere Elements
                                  How far do you get into Premiere Elements 12 before you get the display card error message? Can you get as far as seeing the Expert workspace?
                                  Thank you.
                                  ATR
                                  • 15. Re: pilote d'affichage
                                    Hi Bill and ATR,
                                    I have deleted the file....BUT it comes back when I start PE12!!!  I saw it when it came back as I had the EP12 Folder opened. Consequently, I have exactly the same error...
                                    Incredible!
                                    ATR: It take not a so long time before I get the display card error message
                                    Best,
                                    Julien Valentin
                                    • 16. Re: pilote d'affichage
                                      A.T. Romano Level 7
                                      Julien Valentin
                                      Thanks for the follow up.
                                      After you delete the BadDrivers.txt file in the path cited, when the program is reopened a BadDrivers.txt file will be generated by the program (that is normal) but the problem hopefully is gone.
                                      The BadDrivers.txt file deletion was therefore not your answer for your problem. Have you read the rationale behind the deletion of the BadDrivers.txt file when display card error message present? If not, please see post numbered 10 in the following older thread in which BadDrivers.txt file deletion first became a major remedy.
                                      Since that time until now, the BadDrivers.txt file has resolved the issue when having the latest version of the video card driver was not the answer.
                                      Please remind me,
                                      a. Is your computer working with 1 or 2 video cards/graphics cards?
                                      b. Are you working from a multi-computer monitor set up?
                                      Thanks.
                                      ATR
