2 Replies Latest reply on Dec 12, 2013 8:27 AM by cbianco251
    Help with an if/then script in a writable pdf form
    cbianco251
      I am working a performance review and need some help.  On the recap page there are 5 fields that sum up into a total.  That total then can fall into one of three score brackets.  How can I set it up so the appropriate score bracket is highlighted in a specific color based on the total.
      For example- if the total field is 0-29, then the box that has the range of 0-29 would highlight in red.  If the total is 30-39, then the box that has the range 30-39 would highlight yellow and if the total is 40-45 it would highlight that box in green.
      Is this possible and how do I do it?
        • 1. Re: Help with an if/then script in a writable pdf form
          Yes one could do this with a custom JavaScript validation for the total field.
          var StrokeColor = "T"; // clear stroke color;
          switch(true) {
          case event.value < 0) :
          StrokeColor = "T";
          break;
          case (event.value < 30) :
          StrokeColor = color.red;
          break;
          case(event.value < 40) :
          StrokeColor = color.yellow;
          break;
          case(event.value <= 45):
          StrokeColor = color.green;
          break;
          default:
          StrokeColor = "T";
          break;
          var oTotal = this.getField(event.target.name);
          oTotal.strokeColor = StrokeColor;
          • 2. Re: Help with an if/then script in a writable pdf form
            cbianco251 Level 1
            Thank you for responding!  Forgive me this is all Greek to me so I have a few more questions.  I don't want the total field to change colors I would like the have one of the three boxes become highlighted based on the value in the total box (and that may be what you sent over and I just don't understand!)  So I guess I would need to put a validate code in each of the boxes?
