1 Reply Latest reply on Dec 13, 2013 3:51 AM by moccamaximum
    Clickable World Map
    Tony Heagren Level 1
      Hi all,
      I asked a question recently but I did it badly and I think maybe people thought it was a more complex problem than it was..
      So this time (with example) I'm trying again.
      Scenario:
      Map of the world.
      Click a country.
      A box zooms out (which I will populate with info).
      basic online example:
      www.heagren.com/map
      Two highlighted countries (Nigeria and Indonesia).
      Click each one (then use the X to close the info box).
      The zoom clip in the example is just a very basic classic tween.
      What I need is a zoom clip that will start on the country clicked and end in the same final position each time. Each country has an invisible button on it (nigeria_Btn, USA_Btn, Germany_Btn) etc and ideally I would use these as a target "start point" within the code rather than _x _y coordinates.
      I hope this can be quite easily achieved with a scripted animation but the code is beyond me so I'm looking for ideas and inspiration !
      (and help…)
      All and any help much appreciated.
      Best wishes
      Tony
        • 1. Re: Clickable World Map
          moccamaximum Level 5
          ActionScript 3 (No use to restrict yourself to as1/2 with such simple requirements)
          push all the countries you want clickable into an array
          var country_arr:Array = [];
          country_arr.push(nigeria_Btn);
          country_arr.push(Germany_Btn);
          //etc.
          then create a loop
          for (var i:int = 0;i<country_arr.length;i++){
          country_arr.addEventlistener(MouseEvent.CLICK, zoomFromTo);
          function zoomFromTo(e:MouseEvent):void{
            var startPoint:Point = new Point(e.stageX, e.stageY);
            var startScale:Number = 0.1;
            var endPoint:Point = new Poiint([ enter here the registration point of the infobox will be]);
          var endScale:Number = 1;
          //use all these data to program your tween
          // you can learn to program tweens here: http://www.republicofcode.com/tutorials/flash/as3tweenclass/
