• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Design Time Control Shortcut Information Disappearing
New Here ,
Dec 07, 2007 Dec 07, 2007
I am using a visible Design Time Control Shortcut in RoboHelp X5. It calls up a video (.swf). I type the path into the field called "Program to run when shortcut is activated". I can save it and build the .chm file and the video link works. But when I close Robohelp and then open it back up, the path I typed in disappears and the link is broken. Why is this happening?
Views
315
Translate
Translate
Report
Report
Community guidelines
community guidelines
Valorous Hero ,
Dec 09, 2007 Dec 09, 2007
Hi Brook21679
You are linking to a .SWF. Your use of a control seems to indicate the .SWF will remain outside the .CHM, right? If so, you may need to script things using JavaScript to construct your path on the fly. I have a topic on my site that describes this. You may view it by clicking here.
Otherwise, I'd simply add the .SWF to my baggage files list and link from there.
Sincerely... Rick
Votes
Translate
Translate
Report
Report
New Here ,
Dec 10, 2007 Dec 10, 2007
I have never worked with baggage files. Can you explain how to use them and link to them in more detail? Will this make my file very big? We will eventually have many, many videos and have had to take that into consideration when making these links.
Votes
Translate
Translate
Report
Report
Valorous Hero ,
Hi again Brook21679
Basically it's as simple as expanding the Baggage Files pseudo folder in your Project Manager pane. Then choose to add the file.
When considering file size, it might be better to think of it this way. If you add to baggage, the files are inside the .CHM and while it will indeed increase in size, you will have the same space requirements whether the movies are inside the .CHM or left out. It's just that you have more files to distribute.
Cheers... Rick
Votes
Translate
Translate
Report
Report
LEGEND ,
Click here for an explanation.
Votes
Translate
Translate
Report
Report
Guest
Jan 10, 2008 Jan 10, 2008
LATEST
I've had exactly this problem. I use a shortcut to open an external .htm file and everything works fine until I close, re-open, then re-generate the .chm.
I initially make my shortcut go to <C:/MyProgram/APP_DATA/Index.htm>, or even <../MyProgram/APP_DATA/Index.htm>, but then if I close the help project it turns into just <index.htm>.
I'd love to know a better way of dealing with this rather than re-entering the full path everytime I generate a new compiled help fiIe. Luckily this is the only external bookmark, otherwise that would be rediculous.
Votes
Translate
Translate
Report
Report
Resources
RoboHelp Documentation
Download Adobe RoboHelp
