2 Replies Latest reply on Jan 13, 2014 3:39 AM by boxofspiders
    timeline troubles/question
    Ellen Brouns
      Hi!
      I have some questions..
      (See image for more information...)
      1.When the animation plays reverse, i want it to play faster..
      Is there any way I can do this? By code maybe?
      2.Also. When the animation played backwards, and then forewards again I want it to stop at 'mouseover'.
      How can I do this?
      If i put a trigger stop between them, it also stopt when it is playing backwards.
      I really hope someone knows how to do this!
      Thankyou,
      Kind regards, Ellen
        • 1. Re: timeline troubles/question
          alexmathayes
          I too want to know how to be able to do this, possibly through code I guess. But, I have no idea how to start. I tried to look for information but nothing found as of yet
          • 2. Re: timeline troubles/question
            boxofspiders Level 1
            1. I have suggested a solution to this on your other post.
            2. Add the stop() as a mouseEnter/mouseOver event on the symbol that is being animated that will stop the playhead at its current location, a mouseLeave play() will restart the animation but in the 'play' direction, You could then use a variable to determine which direction the playhead was moving and always send it in the same direction when mousing out, if you need/want it to do that. Hope this helps
