9 Replies Latest reply on Dec 16, 2013 11:32 AM by pixxxel schubser
    how to select and paint the triangle?
    Andy_Bat1 Level 1
      I want to make an imitation cutout mat.
      Created and filled two colors 4 rectangular areas - sections mat. Now you need to fill in the corners. I can calculate pixel by pixel rows and fill them, but it seems to me that there must be a simpler solution.In the example script - create a blank document, fill the new layer rectangel area (this will portray the picture) in the Layers palette make this layer active and run the script.
      Help me paint 2 color corner number 2 :-)
      Thanks !
      #target photoshop;
      var fillColor1 = new SolidColor()
      fillColor1.rgb.red = 255;
      fillColor1.rgb.green = 10;
      fillColor1.rgb.blue = 10;
      var fillColor2 = new SolidColor()
      fillColor2.rgb.red = 155;
      fillColor2.rgb.green = 50;
      fillColor2.rgb.blue = 100;
      // you can change this parametr
      var widthSrez = 20;
      main(0)
      function main(type){//---------------------------------------------------------
          var mySelection =new Array(4);
          for(var o=0;o<mySelection.length;o++){
          mySelection[o] = new Array(4)
          var doc =  app.activeDocument;
          var bounds = doc.activeLayer.bounds;
          var newLayer = doc.artLayers.add();
          newLayer.name =  'Срез' ;
      switch(type){
          case 0:
          //left
              mySelection[0][0] =bounds[0].value;
              mySelection[0][1] =bounds[0].value+widthSrez;
              mySelection[0][2] =bounds[1].value;
              mySelection[0][3] =bounds[3].value;
              mySelection[0][4] =1;
          //top
              mySelection[1][0] =bounds[0].value;
              mySelection[1][1] =bounds[2].value;
              mySelection[1][2] =bounds[1].value;
              mySelection[1][3] =bounds[1].value+widthSrez;;
              mySelection[1][4] =1;
         //right
              mySelection[2][0] =bounds[2].value - widthSrez;
              mySelection[2][1] =bounds[2].value;
              mySelection[2][2] =bounds[1].value + widthSrez;
              mySelection[2][3] =bounds[3].value- widthSrez;
              mySelection[2][4] =2;
         //bottom
              mySelection[3][0] =bounds[0].value+ widthSrez;
              mySelection[3][1] =bounds[2].value;
              mySelection[3][2] =bounds[3].value-widthSrez;
              mySelection[3][3] =bounds[3].value;
              mySelection[3][4] =2;
          break;
          case 1://other type
          break;
          case 2://other type
          break;
          case 3://other type
          break;
                  for(var p=0;p<mySelection.length;p++){
                  var newSelect = Array(
                      Array(mySelection[p][0], mySelection[p][2]),
                      Array(mySelection[p][1], mySelection[p][2]),
                      Array(mySelection[p][1], mySelection[p][3]),
                      Array(mySelection[p][0],mySelection[p][3]),
                      Array(mySelection[p][0],mySelection[p][2])
       doc.selection.select(newSelect);
             if(mySelection[p][4]==1)
                 doc.selection.fill (fillColor1, ColorBlendMode.NORMAL,100,false);
              else{
                  doc.selection.fill (fillColor2, ColorBlendMode.NORMAL,100,false);
                  //in this place paint the corners !!
                 doc.selection.deselect()
        • 1. Re: how to select and paint the triangle?
          Why not make the selection you want in the first place. years ago I create a simple dumb script to be user by action that created  virtual frames about images. The script simply made a 1" selection on the left side with 45degree mitered corners the action filled this with a frame pattern on a new layer.
          http://mouseprints.net/old/dpr/Examples/FramingFrames.jpg
          // A Script by JJMack used by Framing Actions
          // This script set a selection to be used for
          // the left side of a 1" mitered frame
          // This script is supplied as is. It is provided as freeware.
          // The author accepts no liability for any problems arising from its use.
          <javascriptresource>
          <about>$$$/JavaScripts/OneInchMiteredLeftEdgeSelection/About=JJMack's One Inch Mitered Left Edge Selection.^r^rCopyright 2009 Mouseprints.^r^rScript utility for action.^rNOTE:One Inch Mitered Left Edge Selection!</about>
          <category>JJMack's Action Utility</category>
          </javascriptresource>
          leftsideframeselect();
          function leftsideframeselect () {
          // validate that a document is open
          if (documents.length < 1) {
                    alert("No Open Document!");
                    return;
          // Set the ruler units to PIXELS
          var orig_ruler_units = app.preferences.rulerUnits;
          app.preferences.rulerUnits = Units.PIXELS;
          var doc = activeDocument;
          var height = doc.height.value;
          var dpi = doc.resolution;
          var frameRef = [
          [0,0],
          [0,height],
          [dpi,(height-dpi)],
          [dpi,dpi],
          doc.selection.select(frameRef);
          // Reset units to original settings
          app.preferences.rulerUnits = orig_ruler_units;
          Example of action output
          http://mouseprints.net/old/dpr/Examples/LastExample.jpg
          • 2. Re: how to select and paint the triangle?
            pixxxel schubser MVP & Adobe Community Professional
            Hi Andy_Bat1,
            here is another way.
            Actually you do not need math.
            Create a selection. Create a smaller selection and subtract it from the previous one. Fill this with color 1.
            Create a triangular selection and subtract it from the previous one.
            Fill this with color 2.
            #target photoshop
            // SelectionAndCreate2coloredFrameBorder.jsx
            // http://forums.adobe.com/thread/1357492?tstart=0
            var aDoc = app.activeDocument;
            var ori_units = app.preferences.rulerUnits;
            var Abst = 20;
            var newLayer = aDoc.artLayers.add();
            var Br = aDoc.width;
            var Ho = aDoc.height;
            var nBr = Br-Abst;
            var nHo = Ho-Abst;
            aDoc.selection.selectAll();  // first
            aDoc.selection.select([[Abst,Abst],[Abst,nHo],[nBr,nHo],[nBr,Abst]],SelectionType.DIMINISH);  // second
            aDoc.selection.fill (fillColor1, ColorBlendMode.NORMAL,100,false);
            aDoc.selection.select([[0,Ho],[Br,0],[Br,Ho],[0,Ho]],SelectionType.DIMINISH); // third
            aDoc.selection.fill (fillColor2, ColorBlendMode.NORMAL,100,false);
            app.preferences.rulerUnits = ori_units;
            Works this for you?
            • 3. Re: how to select and paint the triangle?
              var nBr = Br-Abst; var nHo = Ho-Abst; This is not math looks like math to me..... More math then var frameRef = [ [0,0], [0,height], [dpi,(height-dpi)], [dpi,dpi], ]
              • 4. Re: how to select and paint the triangle?
                @JJMack,
                why are you doing this?
                Do we want to help Andy_Bat1 - or do we laugh over each other?
                IMHO your frame based on the resolution is nonsense (standalone).
                And you need four different calculations for each side of the image in your sample. You have not mentioned.
                And yes, I know that each script is pure mathematics.
                But please:
                Simple, but without flexibility and only with fixed values - as desired:
                The way is very simple:
                pixxxel schubser schrieb:
                … Create a selection.
                … Create a smaller selection and subtract it from the previous one. Fill this with color 1.
                … Create a triangular selection and subtract it from the previous one. Fill this with color 2 …
                #target photoshop;
                // SelectionAndCreate2coloredFixFrameBorder.jsx
                var aDoc = app.documents.add (500,500);
                // omitted, so that "no math is necessary" while script is running
                var Abst = 20;
                var nBr = Br-Abst;
                var nHo = Ho-Abst;
                // create a smaller selection based on your own fixed values
                aDoc.selection.select([[20,20],[20,480],[480,480],[480,20]],SelectionType.DIMINISH);
                Have fun
                • 5. Re: how to select and paint the triangle?
                  Yes its all math but  my action only used that script once but it did rotations and transform flips all math as is your use of diminish. Its logic and math that make the world go round. Using logic one can do things in different ways.
                  If I used that math in my script on four side there could be gaps because of the way thing get rounded by Photoshop. So the action only used that script once to miter a short side. The short sides were merged down onto the long sides  which were not mitered.  The action did use an other script so it could know where the long and short side were.
                  We do have fun with Photoshop don't we.  Rotation is a slow operation but was needed in any case so the pattern fill would fill the area correctly I wanted more than simple color frames. The action was also interactive so one can select the frame pattern they want for an image yes my nonsence
                  • 6. Re: how to select and paint the triangle?
                    Andy_Bat1 Level 1
                    Good idea. This script is free ? :-)
                    • 7. Re: how to select and paint the triangle?
                      Andy_Bat1 Level 1
                      A small problem - see attach.
                      3 step
                        doc.selection.select([[Right1,Top],[Right,Top],[Right1,Top1],[Right1,Top1]],SelectionType .DIMINISH);
                              doc.selection.select([[Left,Top],[Right1,Top],[Right1,Bottom1],[Left,Bottom1]],SelectionT ype.DIMINISH);
                              doc.selection.select([[Left,Bottom1],[Left1,Bottom1],[Left,Bottom],[Left,Bottom]],Selecti onType.DIMINISH);
                      and result:
                      Message was edited by: Andy_Bat1
                      • 8. Re: how to select and paint the triangle?
                        All the stuff I hack for Photoshop is free script like that one are included is package like image visualization use this link[ JJMack ]
                        • 9. Re: how to select and paint the triangle?
                          Oops, shame on me.
                          I have only briefly tested using a square image.
                          For rectangles, you need really something more mathematics.
                          e.g. Change this line:
                          to this:
                          aDoc.selection.select([[0,Ho],[Abst+10,nHo-10],[nBr-10,Abst+10],[Br,0],[Br,Ho],[0,Ho]],SelectionType.DIMINISH);
                          That should be enough - without to diminish additional selections.
                          Please give it a try.
                          (Note: necessarily abst + abst +10 +10 must always be smaller than height and width of the image)
