1 Reply Latest reply on Dec 13, 2013 8:50 AM by Josh_Corey
    Evaluation Question
      Could I use the forms central program as a checklist when I evaluate employees?  I like the forms that it creates on my IPad.  I would like to use the information for evaluations and have a signature block for the employee to sign.
        • 1. Re: Evaluation Question
          Josh_Corey Adobe Employee
          Signatures are not supported in FormsCentral, other than that you could certainly use for an employee evaluation, but not including Signatures.
          Adobe EchoSign is Adobe's Signature solution which can be used with PDF forms.  FormsCentral can be used to create PDF forms that do not submit data to FormsCentral, you can create a PDF from FormsCentral and add Signature support with Adobe EchoSign and then add your own "Submit" method to the PDF.
