1 Reply Latest reply on Dec 17, 2007 7:02 AM by ATBash81
    RPC Fault faultString
    Vinay P
      Hi ..
      I createad a simple test application with LCDS, and when I run the application with Tomcat 6 as target webserver from Eclipse, I am getting the following exception.
      I copied JTOM libraries into Tomcat/lib folder and defined the below line in application context.xml under META-INF folder
      <Transaction factory="org.objectweb.jotm.UserTransactionFactory" timeout="60" />
      I also defined the default channel on destination-config.xml with <channel ref="my-rtmp"/>
      [RPC Fault faultString="There was an unhandled failure on the server. javax/transaction/SystemException" faultCode="Server.Processing" faultDetail="null"]
      at mx.data::ConcreteDataService/ http://www.adobe.com/2006/flex/mx/internal::dispatchFaultEvent()
      at DataListRequestResponder/fault()
      at mx.rpc::AsyncRequest/fault()
      at NetConnectionMessageResponder/statusHandler()
      at mx.messaging::MessageResponder/status()
      Please let me show some light where I am missing,
      V
        • 1. Re: RPC Fault faultString
          ATBash81
          Hi
          I'm working withHi
          I get the same error and I don't know how fix it.
          I'm working with Tomcat 5.5.17 and LCDS using the following configuration:
          - JOTM libraries in myApp\WEB-INF\lib;
          - carol.properties file in myApp\WEB-INF\classes with the following properties:
          # JNDI (Protocol Invocation)
          carol.protocols=jrmp
          # Local RMI Invocation
          carol.jvm.rmi.local.call=true
          # do not use CAROL JNDI wrapper
          carol.start.jndi=false
          # do not start a name server
          carol.start.ns=false
          # Naming Factory
          carol.jndi.java.naming.factory.url.pkgs=org.apache.naming
          - context.xml file in myApp\META-INF like this:
          <Context reloadable="true" crossContext="true">
          <Resource name="jdbc/myDB" auth="Container" type="javax.sql.DataSource"
          factory="org.objectweb.jndi.DataSourceFactory"
          driverClassName="com.mysql.jdbc.Driver"
          username="root" password="openview" url="jdbc:mysql://localhost:3306/prova"/>
          <Transaction name="UserTransaction" auth="Container"
          type="javax.transaction.UserTransaction"
          jotm.timeout="60"/>
          </Context>
          - and the myApp\WEB-INF\flex\data_management_config.xml as follow:
          <?xml version="1.0" encoding="UTF-8"?>
          <service id="data-service"
          class="flex.data.DataService">
          <default-channels>
          </default-channels>
          <destination id="dm_anagrafica">
          <adapter ref="java-dao"/>
          <properties>
          <source>openview.sn.AnagraficaAssembler</source>
          <scope>application</scope>
          <metadata>
          <identity property="codid"/>
          </metadata>
          <network>
          <session-timeout>30</session-timeout>
          <paging enabled="true" pageSize="50"/>
          <throttle-inbound policy="ERROR" max-frequency="500"/>
          <throttle-outbound policy="REPLACE" max-frequency="500"/>
          </network>
          </properties>
          </destination>
          <adapters>
          <adapter-definition id="actionscript" class="flex.data.adapters.ASObjectAdapter" default="true"/>
          <adapter-definition id="java-dao" class="flex.data.adapters.JavaAdapter"/>
          </adapters>
          </service>
          Please try to help me.
