0 Replies Latest reply on Dec 16, 2013 9:49 AM by graphics26
    Active X can not create running Scriptlistener VB code in Creative Cloud Photoshop
    graphics26
      Currently, I am recieving an Active X can not create error when running this code. I use Visual Studio 2012 run as administrator in x86 mode, Creative Cloud 32bit run as administrator. OS is windows .
      I am able to access the com library for CC in VS. When I run into troubleshooting this  Script listener code, this type of code appears in several different functions throughout the application. I am getting an Active X error when the CreateObject("Photoshop.ActionDescriptor") is hit.
      I am also logged in as an administrator of the box. I have created the process from a scriptlister log with the CS6 Scriptlistener in CC.
      Any direction or feedback is appreciated. I need to know if I am missing something obvious.
      Thank you,
        Sub psAddGuide(ByVal pixelLocation As Integer, ByVal orientation As Integer) '0 = vertical, 1 = horizontal
              If orientation = 1 Or orientation = 0 Then
                  Dim orientationID As String = ""
                  If orientation = 0 Then
                      orientationID = "Vrtc"
                  Else
                      orientationID = "Hrzn"
                  End If
                  'Script Listener code - don't blame me.
                  Dim objApp = CreateObject("Photoshop.Application")
                  REM Use dialog mode 3 for show no dialogs
                  Dim dialogMode As Integer = 3
                  Dim id6
                  id6 = objApp.CharIDToTypeID("Mk  ")
                  Dim desc3
                  desc3 = CreateObject("Photoshop.ActionDescriptor")
                  Dim id7
                  id7 = objApp.CharIDToTypeID("Nw  ")
                  Dim desc4
                  desc4 = CreateObject("Photoshop.ActionDescriptor")
                  Dim id8
                  id8 = objApp.CharIDToTypeID("Pstn")
                  Dim id9
                  id9 = objApp.CharIDToTypeID("#Pxl")
                  Call desc4.PutUnitDouble(id8, id9, pixelLocation)
                  Dim id10
                  id10 = objApp.CharIDToTypeID("Ornt")
                  Dim id11
                  id11 = objApp.CharIDToTypeID("Ornt")
                  Dim id12
                  id12 = objApp.CharIDToTypeID(orientationID)
                  Call desc4.PutEnumerated(id10, id11, id12)
                  Dim id13
                  id13 = objApp.CharIDToTypeID("Gd  ")
                  Call desc3.PutObject(id7, id13, desc4)
                  Call objApp.ExecuteAction(id6, desc3, dialogMode)
              End If
          End Sub
