1 Reply Latest reply on Dec 7, 2007 3:09 PM by gmaa0406
    Need Help With Multiple Volume Controls
      Not very experienced but I've made a five channel mixer in Flash 8 Pro using the stock fader & pan knobs from the built-in library. I've also added a play & stop button for each channel. Each channel contains a different song. The play & stop buttons work correctly...When a song is selected the other stops etc. The problem is that the songs play at the volume level set in the script as a starting point but I can't change the volume with the fader. The fader moves correctly but no change in volume. The fader has built-in script as do the pan knobs & they don't work either.
      Here's a link to the web page this mixer is on.
      I will post script or email it if necessary. Need a solution ASAP.
      Thanks for your time,
